petalinux-create can't find librdi_commonxillic.so
Hi Xilinx,
I'm using Petalinux 2019.1, Ubuntu 18.04, x86_64. When I run petalinux-create (Usage and output shown below) I get the 'not found' error. I'm not having any other petalinux problems. First I checked that the file exists:
(LD_LIBRARY_PATH  = /opt/pkg/petalinux/2019.1/tools/xsct/lib/lnx64.o)
tgs@grinder:~/petalinux/xilinx-zc706-2019.1$ ls -l /opt/pkg/petalinux/2019.1/tools/xsct/lib/lnx64.o/librdi_commonxillic.so
-rwxr-xr-x 1 tgs tgs 3118192 May 11 13:09 /opt/pkg/petalinux/2019.1/tools/xsct/lib/lnx64.o/librdi_commonxillic.so
file $LD_LIBRARY_PATH/librdi_commonxillic.so
/opt/pkg/petalinux/2019.1/tools/xsct/lib/lnx64.o/librdi_commonxillic.so: ELF 64-bit LSB shared object, x86-64, version 1 (GNU/Linux), dynamically linked, stripped
When I run the create command I get this:
tgs@grinder:~/petalinux/xilinx-zc706-2019.1$ petalinux-create -t apps --template autoconf --name CLServer --enable --force
INFO: Create apps: CLServer
WARNING: Component "/home/tgs/petalinux/xilinx-zc706-2019.1/project-spec/meta-user/recipes-apps/CLServer" already exists.
WARNING: --force parameter specified, overwriting
INFO: New apps successfully created in /home/tgs/petalinux/xilinx-zc706-2019.1/project-spec/meta-user/recipes-apps/CLServer
INFO: Enabling created component...
INFO: sourcing bitbake
INFO: oldconfig rootfs
INFO: CLServer has been enabled
Failed to open PetaLinux lib: librdi_commonxillic.so: cannot open shared object file: No such file or directory.
When I do an ltrace on the above command this is the tail of the output:
getuid() = 1000
unsetenv("PETALINUX_ARCH_MICROBLAZE") = <void>
unsetenv("PETALINUX_ARCH_ZYNQ") = <void>
unsetenv("PETALINUX_ARCH_AARCH64") = <void>
setenv("PETALINUX_ARCH_MICROBLAZE", "y", 1) = 0
setenv("PETALINUX_ARCH_ZYNQ", "y", 1) = 0
setenv("PETALINUX_ARCH_AARCH64", "y", 1) = 0
dlopen("librdi_commonxillic.so", 10Couldn't find .rel*.plt section in "/opt/pkg/petalinux/2019.1/tools/xsct/lib/lnx64.o/libisl_iostreams.so"
The project appears to have already been created when the error occurs but I'm making no assumptions that it was successful. How can we fix this?
Cheers, Tom
