joseer
petalinux doesn't boot with uart-usb unplugged
I'm working with a custom board Zynq Ultrascale+ based running petalinux 2018.3.
In my application I need to reduce the booting time as much as possible but like in this post: https://forums.xilinx.com/t5/Embedded-Linux/Disabling-PHY-auto-negotiation/td-p/435288 I'd like to get rid of the "PHY auto negotiation"  because it consumes ~15s not necessary for my application.
I found how to avoid the auto negotiation editing u-boot running: "petalinux-config -c u-boot-xlnx" and disabling "Xilinx Ethernet GEM":
Petalinux boots faster now while I have the uart connected (usb-uart cable plugged in) and obviously I can see it in the console using TeraTerm.
Just to clarify the uart-usb cable is an externarl ftdi chip which plugs into the board through a custom connector.
The problem is that if I disconnect the "uart cable" petalinux doesn't boot, and I don't understand the relation between the change I've done (disable PHY auto negotiation) and the fact it doesn't boot when the uart is disconnected,
Any ideas why is this happening?
Thanks in advance.
barco2
most likely you forgot to add a pulldown to your UART input pin. When you unplug the USB cable, the USB UART is probably not powered anymore (assuming you have connected it to USB power). Then the UART RX picks up noise which i turn lets u-boot stop auto-booting and enter interactive mode.
Either add a pulldown to your UART input or make u-boot ignore the input by setting CONFIG_BOOTDELAY=-2
Cheers
Martin
barco2
Cheers
Martin
joseer
Hi @barco2 ,
Thanks for your answer, yes that's right the pull-ups are missing in my design (I can add them easily) but I've changed the CONFIG_BOOTDELAY to -2 and now it boots with the uart-usb cable disconnected (when the Xilinx Ethernet GEM is disabled).
If the problem is the uart port noise, do you know why it boots regardless the uart cable status, when the Xilinx Ethernet GEM is enable?
barco2
Hi @joseer ,
I can only guess, that you have somewhat different noise levels depending on the GEM state. But if it comes to noise usually things get pretty odd and undeterministic. It could also be a different boot timing and thus in one case u-boot looks for keystrokes just in the wrong time window...
Cheers
Martin
