petalinux environment setup problem on xilinx sdk
We have Installed ubuntu 14.04 LTS OS.We have Downloaded the Xilinx_Vivado_SDK_Lin_2014.1 and petalinux-v2014.4-final-installer.run from Xilinx Download link.
First we have installed the Xilinx_Vivado_SDK_Lin_2014.1.Then we have installed the petalinux-v2014.4-final-installer.run.Then, Opened the terminal and started to Setup PetaLinux Tools Working Environment.
mindflow@mindflow:~$ source /opt/petalinux-v2014.4-final/settings.sh
PetaLinux environment set to '/opt/petalinux-v2014.4-final'
INFO: Checking free disk space
INFO: Checking installed tools
INFO: Checking installed development libraries
INFO: Checking network and other services
WARNING: No tftp server found - please refer to "PetaLinux SDK Installation Guide" for its impact and solution.
Verify that the working environment has been set by using below commands.
mindflow@mindflow:/opt/Xilinx/SDK/2014.4/bin$ echo $PETALINUX
/opt/petalinux-v2014.4-final.
Opened the sdk from terminal by using commands, as shown below.
mindflow@mindflow:/opt/Xilinx/SDK/2014.4/bin$ sudo ./xsdk.
Sdk opened successfully but we are getting error in console as “petalinux environment is not setup”, as shown below.
PetaLinux Environment is not setup, please run source './settings.sh' before running eclipse.
plat[dirt] - Platform Configuration Marked Dirty.
Any suggestions or help is very much appreciated, I have been stuck for days.
Please go through the below attachement for complete installation details.
Thank you,
Ranjith
