petalinux error
I used to generate only brought petalinux Ethernet system, but when I assign IP addresses, it found that can't find the device.TBZ43OO7SIUEZTZLNO[1EMQ.jpg
When I use the SDK's own LWip cases to test, found that Ethernet can be connected.PV{3${G8QI)NKKB@K8HEFL6.png
at the same time I also found the Ethernet in the device tree. This problem bothering me for a long time, who knows what reason is this?
Re: petalinux error
we would need ALOT more info here.
What does your HW look like? Are you using Zynq GEM, are you using AXI Ethernet?
GMII, RGMII, SGMII? ECT
Are you using a development board? Which one. If using a development board, have you tried the BSP for this board.
Re: petalinux error
Thanks for your answer,I am using my company produces its own development board.And I use the SDK LWip tested my BSP,found it to be no problem.
