petalinux eth0 problem
I've built petalinux on my zynq, but I have problem with eth0. ifconfig works but connection not. If i want check mii info I have got mii not found. Where can be a problem.
my system-top.dts file:
aliases{
ethernet0=&gem0;
&gem0 {
    phy-handle = <&phy0>;
    ps7_ethernet_0_mdio: mdio {
        #address-cells = <1>;
        #size-cells = <0>;
        phy0: phy@0 {
            compatible = "marvell,88e1510";
            device_type = "ethernet-phy";
            reg = <0>;
Your device tree specifies a PHY address of 0... is that what your hardware actually has?
If the PHY address correct, then check the configuration of the MDIO pins in Vivado. If they incorrect, you will need to fix it, then generate a new FSBL.
Sometimes, PHY chips are held in reset via a GPIO pin. If that is the case on your board, this needs to be configured as well, before the PHY will be detected.
the address and pins are correct. It's problem with all peripherals ethernet uart spi ... Linux works but i can't communicate with any phy Only gpio works
Do you have any ethernet connection at all? If you connect to a router/switch do the lights come on?
I found with the marvell 88e1510 that the phy has a delay on outgoing traffic, no idea why it defaults to on but you can turn it off. I've not found the "proper" way to turn it off but adding the following line to your dts file will turn off the delay and then issue a soft reset to the phy (needed for the change to actually happen)
marvell,reg-init = <2 21 0xffef 0x00 0 0 0x7fff 0x8000>;
Hope that helps
Jon
@kmbm
Do you observe the same behaviour at U-boot stage?
Achutha
