Observer umer.sabeen
petalinux failed to build linux error in making u-boot
Hello
I am just moving from windows 7 to ubuntu 14.04, I installed petalinux 2015.2 and vivado 2015.5.2 and petalinux version 2015.2
I created the project $petalinux-create -t project -s ~/Avnet-Digilent-ZedBoard-v2015.2.1-final.bsp
then
$petalinux-build    it generate all the images/files
After that I added hardware description file in this project
$petalinux-config --get-hw-description=~/my_project/my_project.sdk/
petalinux-config (i set for sd card)
again run the petalinux-build command
INFO: Checking component...
INFO: Generating make files and build linux
INFO: Generating make files for the subcomponents of linux
INFO: Building linux
[INFO ] pre-build linux/rootfs/fwupgrade
[INFO ] pre-build linux/rootfs/peekpoke
[INFO ] pre-build linux/rootfs/uWeb
[INFO ] build system.dtb
[ERROR] Error: /home/sana/my_program/gpio_spi/petalinux/zed_bsp_proj/Avnet-Digilent-ZedBoard-2015.2/subsystems/linux/configs/device-tree/system-top.dts:21.2-3 label or path, 'flash0', not found
[ERROR] make[1]: *** [system.dtb] Error 255
ERROR: Failed to build linux
then i disabled the followng lines
&flash0 {
compatible = "spansion,s25fl256s1";
again  petalinux-build
[INFO ] pre-build linux/rootfs/myapp
[INFO ] build linux/kernel
[INFO ] update linux/u-boot source
[INFO ] generate linux/u-boot configuration files
[INFO ] build linux/u-boot
[ERROR] make[4]: *** [lib/asm-offsets.s] Error 1
[ERROR] make[4]: *** [arch/arm/lib/asm-offsets.s] Error 1
[ERROR] make[3]: *** [prepare0] Error 2
[ERROR] make[2]: *** [sub-make] Error 2
[ERROR] make[1]: *** [petalinux/Avnet-Digilent-ZedBoard-2015.2/build/linux/u-boot/u-boot-plnx/u-boot] Error 2
I found the some thread here but no solution
https://forums.xilinx.com/t5/Embedded-Linux/Petalinux-2014-2-build-error-u-boot/td-p/542299
https://forums.xilinx.com/t5/Embedded-Linux/Petalinux-fails-to-build-for-new-board-configuration/td-p/644918
If this is the solution how can i remove QsPI or any other solution???
thanks
Re: petalinux failed to build linux error in making u-boot
Hello again
probem Solved :)
the error was in .hdf file. I dsabled the pin M_AXI_GP0_ACLK
Now i enabled it and connect to FCLK_CLK0
Works perfect
Sana
Visitor kg.calrec
If I read you right, you did petalinux-build THEN imported the HDF? You need to do it the other way round.
So now do this:
Clean the build
petalinux-build -x mrproper
Import hardware description
petalinux-config --get-hw-description=/path/to/folder/containing/hdf
Make sure all the configurations are as desired
petalinux-config
petalinux-config -c kernel
petalinux-config -c rootfs
Build the system
petalinux-build
petalinux-build is really bad at passing on build error messages, and will often just carry on silently. If a certain component isn't building properly, change directory to the root of that component (u-boot for example) then runthe following to build it directly and get the error messages.
make clean
make all
Hope that helps.
Hello again
probem Solved :)
Works perfect
Sana
