Voyager
Voyager
petalinux failed to source bitbake
when exit the config I got these error
ERROR: Failed to source bitbake
ERROR: Failed to config project.
Voyager
Voyager
so some thread indicate this could be error cause by installing petalinux as root user? since I'm the only user for the VM Ubuntu. how do I install as non-root user?
Voyager
Voyager
the link "View solution in original post" sends me back in this page. Could you add the right link to solution.
