petalinux for standalone build ?
Is it possible to use petalinux with standalone build for kernel and u-boot ?
And another question , after petalinux-build finished I don't find any rootfs directory as I usually find with yocto build.
Why is it missing ?
Thank you,
ranran
Re: petalinux for standalone build ?
Im not sure if I understand this question, is it possible to use standalone build for kernel and uboot.
Do, you mean can use use the fsbl,pmufw, images from standalone bsp in SDK with your kernel? if so, technically yes,but
I wouldnt recommend it, as the images need to have matching release builds, or you may see issues during boot.
You can see all the directories in table A-2:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_4/ug1144-petalinux-tools-reference-guide.pdf
