dshamgar
petalinux glibc compatibility error (GLIBC_2.29)
i have installed petalinux (2020.01) with all dependencies, and downloaded the BSP for the zcu102 zynqMP:
xilinx-zcu102-v2020.1-final.bsp
i built a petalinux project from the bsp, and i am trying to run qemu with the prebuilt images:
petalinux-boot --qemu --prebuilt 3
i get the following error (all over): see file qemu_error.txt attached
for "petalinux-build" i get the following error: see file build_error.txt attached
my platform is centos7.6 and i am running the petalinux through devtoolset-7 bash.
how can i resolve this please ?
are the errors related to the bsp pre-compilation environment ?
thanks,
doron
dshamgar
after a l-o-n-g debug session i found that i had a collision in the LD_LIBRARY_PATH.
i deleted it (L_LIBRARY_PATH="") and the problem solved.
hope this helps someone in the future.
i will keep investigating about the specific collision and what path is causing the problem.
thanks
dshamgar
thanks
