stonedown
petalinux-image-full has become the default image
I am attempting to transition from petalinux-v2018.2 to petalinux-v2018.3, and I find that petalinux-image-full is the default image. Any idea why that might be the case?
stonedown
Looks like it wasn't the default image so much as it was just looking for that bbappend file. This seemed to help:
$ touch /path/to/project-spec/meta-user/recipes-core/images/petalinux-image-full.bbappend
stonedown
For instance, the following now occurs with petalinux-v2018.3 for my existing project:
$ petalinux-config -c rootfs
[INFO] sourcing bitbake
[INFO] generating plnxtool conf
[INFO] generating meta-plnx-generated layer
[INFO] generating machine configuration
[INFO] configuring: rootfs
[INFO] generating kconfig for Rootfs
Traceback (most recent call last):
  File "rootfs_config.py", line 315, in <module>
    parse_args(sys.argv[1:])
  File "rootfs_config.py", line 290, in parse_args
    extract_packages_dot(packages_user)
  File "rootfs_config.py", line 257, in extract_packages_dot
    with open(packages_dot,'r') as fp:
IOError: [Errno 2] No such file or directory: '/path/to/project-spec/meta-user/recipes-core/images/petalinux-image-full.bbappend'
ERROR: Failed to generate rootfs /path/to/build/misc/rootfs_config/Kconfig.user
ERROR: Failed to config rootfs.
stonedown
rwillis
Did you manage to compile 2018.3 after touching the missing file?
I have the same issue (and created the same file) but build fails later on. First a warning is given:
"WARNING: No recipes available for: </path/to>/project-spec/meta-user/recipes-core/images/petalinux-image.bbappend"
then the build fails:
"ERROR: fsbl-2018.3+gitAUTOINC+56f3da2afb-r0 do_compile: Function failed: do_compile (log file is located at </path/to>/build/tmp/work/zcu102_zynqmp-xilinx-linux/fsbl/2018.3+gitAUTOINC+56f3da2afb-r0/temp/log.do_compile.29694)"
 - Richard
Instead of doing a touch on the missing file I simply moved my old bbappend file to the new name.  I then re-enabled the recipes using petalinux-config -c rootfs.  This allowed my build to complete successfully.
mv </path/to>/project-spec/meta-user/recipes-core/images/petalinux-image.bbappend </path/to>/project-spec/meta-user/recipes-core/images/petalinux-image-full.bbappend
rpjday
I just ran into the same issue, and while I'm about to try the same solution, it's not clear to me what precisely changed between (in my case) 2017.4 and 2018.3 such that the build process is suddenly interested in petalinux-image-full rather then simply petalinux-image.
What config file, or recipe, or .inc file, or .bb file, or whatever, has changed in the meantime to try to find that .bbappend file?
