petalinux jffs2 file system problem
hi,
In my design, a jffs2 filesystem made on emmc is used as root file system. But when a file is created and then deleted, the space is not reclaimed and can't be used again. After running the board for several days, the usage rate reaches to 100% even though only total file size if less than 100MB.
What should I do to re-use those space?
regards
Xiang
