petalinux offline add gcc failed
I use ZCU102 and petalinux 2017.4 ,I have download sstate-rel-v2017.4 repository and I follow the README doc use yocto-config link the  repository path to the petalinux 2017.4
I enable the packagegroup-core-buildessential on petalinux-config -c rootfs ,but then compile error
This is log,
Thanks a lot
