petalinux opencv
 I'm using peitalinnux to create new project, I want to add opencv to the file system, how should I do, my petalinux version 2017.4.Thanks!
Re: petalinux opencv
Hi @zitengxiaxiang
Please follow below steps to add opencv as a part of your rootfs:
vim project-spec/meta-user/recipes-core/images/petalinux-image.bbappend
add below line
IMAGE_INSTALL_append = "opencv"
petalinux-config -c rootfs
user packages --> [*] opencv
petalinux-build
You can find the opencv recipe in this path :petalinux-v2017.4-final/components/yocto/source/aarch64/layers/./meta-oe/recipes-support/opencv/opencv_3.1.bb
Thanks & regards
Aravind
When I run command "petalinux-build",I got an error like picture.What can I do to solve the problem?Thanks!5505b9a8705e609bdc85e27afb5ab37.png
Hi @zitengxiaxiang,
Looks like you are using sstate cache you need to unlock for your recipe.
$ vim project-spec/meta-user/conf/petalinuxbsp.conf
SIGGEN_UNLOCKED_RECIPES += "<recipe_name>"
 Can you post the content of your recipe?
Sandeep
What is recipe_name?and opencv is added in the petalinux where should I find the manual?
Thanks!
Hi @zitengxiaxiang,
Recipe name is nothing but your damageproto
Sandeep
When I run a "petalinux - build" command, I got the error as shown. How to solve the mistake ?
Thanks!
Hi @zitengxiaxiang,
Sometimes if the network is not reachable for the mirrors sites defined in recipes you see do_fetch bitbake task will fail. In this situation you need to run the below commands.
$ cd <plnx-proj-root>/build/downloads
$ wget http://www.freedesktop.org/software/harfbuzz/release/harfbuzz-1.3.0.tar.bz2
$ touch harfbuzz-1.3.0.tar.bz2.done
Note: Make sure you have the right network proxy and git proxy settings configured.
Sandeep
