petalinux-package including RPU .elf file
Is there a way to include the .elf file for the RPU (R5) on an Ultrascale+ device when creating the BOOT.bin with petalinux-package?
--add ./rpu0.elf --cpu=r5-0
or create your own .bif  but just providing these switch is easier.
jeff
jeff
Thanks very much, I just tested it and it works. Interestingly the documentation for the petalinux-package command does not list the r5 as a suitable destination cpu, it only lists the a53.
