petalinux python adding modules
I am building petalinux 2017.4 for z706 and trying to bring up a custom webserver.
I've already enabled python2.7 and python3 in petalinux-config -c rootfs.
Python native SimpleHTTPserver.py (2.7) and socket.server(3.5) both works fine.
python3-setuptools is enabled.
python3 venv works and I am able to create one --without-pip.
Now I want to add flask and some other python modules to venv and work with python like in a big machine, but there is no pip.
How do I do that?
I've seen https://forums.xilinx.com/t5/Embedded-Linux/Add-python-or-any-rpm-on-Petalinux/m-p/716911
and https://www.xilinx.com/support/answers/67160.html
but will it work for python modules?
Is there a simpler way like placing .py files somewhere in petalinux folders or just copying a prepared venv to the board and activating it there?
Thank you.
Tags (2)
Re: petalinux python adding modules
Hi @johnsmith120485 ,
First you need to find the relavent packages in https://layers.openembedded.org/layerindex/branch/morty/recipes/?q=python and then add in petalinuxbsp.conf file as shown below as all the python packages are not available in rootfs menu config.
IMAGE_INSTALL_append = " \
    python \
python-pip \ python3 \
python3-pip \ "
Note: Some python packages are available different meta layers and you can't use those packages if they are not part of your project meta-layers(refer <plnx-proj-root>/build/conf/bblayers.conf)
For example python-flask is part of meta-python(https://layers.openembedded.org/layerindex/branch/morty/recipes/?q=flask) and if you don't include this layer in your project then you can't using python-flask in IMAGE_INSTALL variable.
Sandeep
    python \
python3-pip \ "
Sandeep
Will try this.
Thanks a lot, Sandeep!
UPDATE:
Following the above solution, I've edited file at petalinux/<project_root>/project-spec/meta-user/conf/petalinuxbsp.conf.
After building an image required packages appeared in /usr/lib/python3/site-packages.
To run code example like this
from flask import Flask
app = Flask(__name__)
@app.route("/")
def hello():
    return "Hello World!"
if __name__ == "__main__":
    app.run(host='0.0.0.0',port=80)
python3 hello.py
you have to enable python3-misc (for runpy.py) and python3-html from rootfs config.
As I understand, what happens here:
1) You have to cross-compile python to arm in any way you can, and install packages to the target.
2) Petalinux and Yocto (Open Embedded) projects provide cross-compilling tools and a huge base of recipes to make it easier.
3) As there still may be custom python packages, that are not listed in database, you can write your own recipes to x-compile them.
4) Once x-compiled, a package seems to have an egg or wheel (python installation files). It becomes possible to create a folder on sd-card, containing x-compiled packages for specific projects, and installing them from there into venvs on board (this is what i've not tested so far).
Cheers
