petalinux raw eth?
last time i try out the petalinux ethernet using socket etc, i can get around 400mbs.  is there anyway to run raw to increase the performance?  similar to raw in xapp1026 or other method to increase the performance of ethernet?
Re: petalinux raw eth?
The solution for high speed ethernet is kernel level tcp, or zero-copy or using jumbo frames or a combination of these techniques. Another option is to use UDP instead of TCP which adds significant overhead too.
