petalinux root filesystem type supported by Qemu
Hi all,
I would like to know what are the file system types supported by Qemu.
I see following file system types/options  are available under Image Packaging Configuration:
INITRAMFS
INITRD
JFFS2
NFS
SD Card
Other
Could anyone please throw some light on these file systems and Which among these are supported by QEMU.
I am able to run INITRAMFS with QEMU but when I try SD Card file system type, QEMU is not able to run &  Mount it. So with this observation I assume that SD Card Image packaging is not supported in Qemu. Is this right? I seek some expert comments.
My main trouble is that when I build image by selecting SD Card image packaging I am not able to run Linux, neither on Qemu nor on my Target board.
Thanks & Regards
-Siddhant
Re: petalinux root filesystem type supported by Qemu
There is no such restriction for the guest, it should work. As an example, There is a section in  UG1169 (SD-Card Partitioning and Loading an Ubuntu-coreFile System), refer this
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1169-xilinx-qemu.pdf
Hi @shabbirk,
Thank you for sharing useful doc.
I have gone through this and executed the steps and I am having one doubt here, till steps 6 I  finished, at 7 step, it is asking to mount the partitions, so I assume I have to do "mount /dev/nbd0p1 /media/BOOT" and mount /dev/nbd0p2 /media/rootfs"
after this mounting, I have to copy the contents in those directory. Am I thinking correct?
If I run Petalinux-boot --qemu --prebuilt 3. Would it be able to fetch the files and boot? I am not sure on this. Could you please confirm the flow this booting.
There is a note : This step in not required if performing switch-root.
What is meant by this? I am not able to catch this.
-Regards
Siddhant
hi @siddhant
You may try running petalinux-boot --qemu --kernel instead of prebuilt.
To answer your last query, with switch-root, it means, if you are not using ubuntu, you dont need to actually use it.
ubuntu rootfs will actually switch from initial rootfs
Best Regards
Shabbir
Hi @shabbirk
Thanks for your reply.
I followed the instructions mentioned in QEMU user document and executed the command "petalinux-boot --qemu --kernel"
and got following output on screen at the end, It is getting stuck.
---[snip]
[   19.947767] pca953x 0-0021: interrupt support not compiled in
[   20.028913] ina2xx 3-0040: power monitor ina226 (Rshunt = 5000 uOhm)
[   20.095915] ina2xx 3-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[   20.153415] ina2xx 3-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[   20.211893] ina2xx 3-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[   20.265730] ina2xx 3-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[   20.317843] ina2xx 3-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[   20.364826] ina2xx 3-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[   20.413813] ina2xx 3-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[   20.481319] ina2xx 3-004a: power monitor ina226 (Rshunt = 5000 uOhm)
[   20.528729] ina2xx 3-004b: power monitor ina226 (Rshunt = 5000 uOhm)
[   20.571809] i2c i2c-0: Added multiplexed i2c bus 3
[   20.648324] ina2xx 4-0040: power monitor ina226 (Rshunt = 2000 uOhm)
[   20.703674] ina2xx 4-0041: power monitor ina226 (Rshunt = 5000 uOhm)
[   20.755334] ina2xx 4-0042: power monitor ina226 (Rshunt = 5000 uOhm)
[   20.800882] ina2xx 4-0043: power monitor ina226 (Rshunt = 5000 uOhm)
[   20.863806] ina2xx 4-0044: power monitor ina226 (Rshunt = 5000 uOhm)
[   20.916076] ina2xx 4-0045: power monitor ina226 (Rshunt = 5000 uOhm)
[   20.959880] ina2xx 4-0046: power monitor ina226 (Rshunt = 5000 uOhm)
[   21.001232] ina2xx 4-0047: power monitor ina226 (Rshunt = 5000 uOhm)
[   21.032451] i2c i2c-0: Added multiplexed i2c bus 4
[   21.175151] max20751 5-0072: Failed to identify chip capabilities
[   21.266858] max20751 5-0073: Failed to identify chip capabilities
[   21.307964] i2c i2c-0: Added multiplexed i2c bus 5
[   21.353992] i2c i2c-0: Added multiplexed i2c bus 6
[   21.389376] pca954x 0-0075: registered 4 multiplexed busses for I2C mux pca9544
[   21.408615] cdns-i2c ff020000.i2c: 400 kHz mmio ff020000 irq 33
[   21.530034] at24 7-0054: 1024 byte 24c08 EEPROM, writable, 1 bytes/write
[   21.560216] i2c i2c-1: Added multiplexed i2c bus 7
[   21.595575] i2c i2c-1: Added multiplexed i2c bus 8
[   21.698869] si570 9-005d: registered, current frequency 300000000 Hz
[   21.725897] i2c i2c-1: Added multiplexed i2c bus 9
[   21.879525] si570 10-005d: registered, current frequency 148500000 Hz
[   21.909017] i2c i2c-1: Added multiplexed i2c bus 10
[   21.947226] i2c i2c-1: Added multiplexed i2c bus 11
[   21.979795] i2c i2c-1: Added multiplexed i2c bus 12
[   22.005043] i2c i2c-1: Added multiplexed i2c bus 13
[   22.047760] i2c i2c-1: Added multiplexed i2c bus 14
[   22.075133] pca954x 1-0074: registered 8 multiplexed busses for I2C switch pca9548
[   22.111410] i2c i2c-1: Added multiplexed i2c bus 15
[   22.145626] i2c i2c-1: Added multiplexed i2c bus 16
[   22.185747] i2c i2c-1: Added multiplexed i2c bus 17
[   22.234468] i2c i2c-1: Added multiplexed i2c bus 18
[   22.275363] i2c i2c-1: Added multiplexed i2c bus 19
[   22.305084] i2c i2c-1: Added multiplexed i2c bus 20
[   22.340080] i2c i2c-1: Added multiplexed i2c bus 21
[   22.372161] i2c i2c-1: Added multiplexed i2c bus 22
[   22.403102] pca954x 1-0075: registered 8 multiplexed busses for I2C switch pca9548
[   22.428181] cdns-i2c ff030000.i2c: 400 kHz mmio ff030000 irq 34
[   22.472935] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: CPU DAI (null) not registered
[   22.510681] zynqmp_gpd_attach_dev error -13, node 35
[   22.536456] cdns-spi ff040000.spi: failed to add to PM domain pd-spi0: -13
[   22.573183] zynqmp_gpd_attach_dev error -13, node 36
[   22.593477] cdns-spi ff050000.spi: failed to add to PM domain pd-spi1: -13
[   22.661933] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[   22.718061] rtc_zynqmp ffa60000.rtc: setting system clock to 2018-10-10 13:56:03 UTC (1539179763)
[   22.759625] of_cfs_init
[   22.791390] of_cfs_init: OK
[   22.835683] clk: Not disabling unused clocks
[   22.889249] ALSA device list:
[   22.923693]   No soundcards found.
[   22.976203] xilinx-dp-snd-card fd4a0000.zynqmp-display:zynqmp_dp_snd_card: ASoC: CPU DAI (null) not registered
[   23.018091] zynqmp_gpd_attach_dev error -13, node 35
[   23.042434] cdns-spi ff040000.spi: failed to add to PM domain pd-spi0: -13
[   23.082552] zynqmp_gpd_attach_dev error -13, node 36
[   23.110734] cdns-spi ff050000.spi: failed to add to PM domain pd-spi1: -13
[   23.150012] Waiting for root device /dev/mmcblk0p2...       // No response after this.
I think qemu is not able to detect the /media/rootfs. How to resolve this? Any pointer?
I appreciate your time and valuable suggestions.
-Regards
