Visitor rang
petalinux sdk build fails on pixz-native
hi. i am building a project for zcu106 with petalinux 2018.3 i created the project from the xilinx-zcu106-v2018.3-final-v2.bsp bsp. the petalinux-build was successful but when i try to create the sdk (petalinux-build -s) i get this errors
ERROR: pixz-native-1.0.6-r0 do_compile: oe_runmake failed
ERROR: pixz-native-1.0.6-r0 do_compile: Function failed: do_compile (log file is located at /home/elsec-linux/extend-disk/builds/zcu106/projects/xilinx-zcu106-2018.3/build/tmp/work/x86_64-linux/pixz-native/1.0.6-r0/temp/log.do_compile.16449)
ERROR: Logfile of failure stored in: /home/elsec-linux/extend-disk/builds/zcu106/projects/xilinx-zcu106-2018.3/build/tmp/work/x86_64-linux/pixz-native/1.0.6-r0/temp/log.do_compile.16449
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 8
| (CDPATH="${ZSH_VERSION+.}:" && cd ../../../../../../../../../../../../../home/elsec-linux/extend-disk/builds/zcu106/projects/xilinx-zcu106-2018.3/build/tmp/work/x86_64-linux/pixz-native/1.0.6-r0/pixz-1.0.6 && autoheader)
| /bin/sh: line 0: cd: ../../../../../../../../../../../../../home/elsec-linux/extend-disk/builds/zcu106/projects/xilinx-zcu106-2018.3/build/tmp/work/x86_64-linux/pixz-native/1.0.6-r0/pixz-1.0.6: No such file or directory
| Makefile:362: recipe for target '../../../../../../../../../../../../../home/elsec-linux/extend-disk/builds/zcu106/projects/xilinx-zcu106-2018.3/build/tmp/work/x86_64-linux/pixz-native/1.0.6-r0/pixz-1.0.6/config.h.in' failed
| make: *** [../../../../../../../../../../../../../home/elsec-linux/extend-disk/builds/zcu106/projects/xilinx-zcu106-2018.3/build/tmp/work/x86_64-linux/pixz-native/1.0.6-r0/pixz-1.0.6/config.h.in] Error 1
| ERROR: oe_runmake failed
| WARNING: /home/elsec-linux/extend-disk/builds/zcu106/projects/xilinx-zcu106-2018.3/build/tmp/work/x86_64-linux/pixz-native/1.0.6-r0/temp/run.do_compile.16449:1 exit 1 from 'exit 1'
| ERROR: Function failed: do_compile (log file is located at /home/elsec-linux/extend-disk/builds/zcu106/projects/xilinx-zcu106-2018.3/build/tmp/work/x86_64-linux/pixz-native/1.0.6-r0/temp/log.do_compile.16449)
ERROR: Task (virtual:native:/hdd/elsec-linux-ext/petalinux/petalinux-2018.3/components/yocto/source/aarch64/layers/core/meta/recipes-extended/pixz/pixz_1.0.6.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 4998 tasks of which 4986 didn't need to be rerun and 1 failed.
does anyone know how to fix it
thanks
Visitor rang
Re: petalinux sdk build fails on pixz-native
after i did dos2unix on the config.h.in file it solved the problem? strange as i am working on linux
