changliu
petalinux started with a SD card and placed the file system in the SD card partition, but encountered problems at startup
The petalinux system was created and the SD card was successfully started, but subsequent changes want to put the file system on the SD card, according to the tutorial changes after the problem, prompted can not identify the mmcblk0p2(179,2). At the same time, for some reason, the profile is marked red. My configuration and print information are shown in the figure.
evatrostaz
Check if your SD Card is not locked by mechanical switch.
I had similar problem with ZCU106 board - https://www.xilinx.com/support/answers/73079.html
changliu
Thank you, I use the development board "zedboard", Is it the same way to modify it
