7rabbit
petalinux stopped at "Running local start scripts."
Hello everyone I used petalinux to compile for my spartan 3e board with my own hardware design.
after the uboot I receive:
FS-BOOT: System initialisation completed.
FS-BOOT: Booting from FLASH. Press 's' for image download.
FS-BOOT: Booting image...
SDRAM :
	Enabling caches :
		Icache:OK
		Dcache:OK
	U-Boot Start:0x8dfc0000
	Malloc Start:0x8df80000
	Board Info Start:0x8df7ffd0
	Boot Parameters Start:0x8df6ffd0
FLASH: 16 MB
ETHERNET: MAC:00:0a:35:00:22:01
## Booting image at 89080000 ...
   Image Name:   PetaLinux Kernel 2.6
   Image Type:   Microblaze Linux Kernel Image (uncompressed)
   Data Size:    2810000 Bytes =  2.7 MB
   Load Address: 8c000000
   Entry Point:  8c000000
   Verifying Checksum ... OK
OK
Found romfs @ 0x8c1b308c (0x000fb000)
#### klimit 8c1cb000 ####
Moving 0x000fb000 bytes from 0x8c1b308c to 0x8c1ca868
New klimit: 0x8c2c6000
Linux version 2.6.20-uc0 (root@ubuntu) (gcc version 3.4.1 ( PetaLinux 0.20 Build -rc1 050607 )) #2 Fri Feb 18 17:03:28 CET 2011
setup_cpuinfo: initialising
setup_cpuinfo: Using full CPU PVR support
setup_memory: max_mapnr: 0x8dfff
setup_memory: min_low_pfn: 0x8c000
setup_memory: max_low_pfn: 0x2000
On node 0 totalpages: 8192
  DMA zone: 64 pages used for memmap
  DMA zone: 0 pages reserved
  DMA zone: 8128 pages, LIFO batch:0
  Normal zone: 0 pages used for memmap
Built 1 zonelists.  Total pages: 8128
Kernel command line: mtdparts=physmap-flash.0:256K(boot),128K(bootenv),128K(config),4M(image),11776K(spare) macaddr=00:0a:35:00:22:01 console=ttyUL0,115200
OPB INTC #0 at 0x81800000
PID hash table entries: 128 (order: 7, 512 bytes)
TIMER at 0x83C00000
disabling early console
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory: 29640k/32768k available
Calibrating delay loop... 24.47 BogoMIPS (lpj=122368)
Mount-cache hash table entries: 512
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
io scheduler noop registered
io scheduler anticipatory registered
xgpio0 #0 at 0x81400000 mapped to 0x81400000 device: 10,185 not using IRQ
xgpio1 #1 at 0x81420000 mapped to 0x81420000 device: 10,186 not using IRQ
xgpio2 #2 at 0x81440000 mapped to 0x81440000 device: 10,187 not using IRQ
uartlite.0: ttyUL0 at MMIO 0x84000000 (irq = 2) is a uartlite
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
eth0: using fifo mode.
eth0: No PHY detected.  Assuming a PHY at address 0.
eth0: Xilinx EMACLite #0 at 0x81000000 mapped to 0x81000000, irq=1
physmap platform flash device: 01000000 at 89000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 8-bit bank
 Intel/Sharp Extended Query Table at 0x0031
Using buffer write method
cfi_cmdset_0001: Erase suspend on write enabled
erase region 0: offset=0x0,size=0x20000,blocks=128
5 cmdlinepart partitions found on MTD device physmap-flash.0
Creating 5 MTD partitions on "physmap-flash.0":
0x00000000-0x00040000 : "boot"
0x00040000-0x00060000 : "bootenv"
0x00060000-0x00080000 : "config"
0x00080000-0x00480000 : "image"
0x00480000-0x01000000 : "spare"
uclinux[mtd]: RAM probe address=0x8c1ca868 size=0xfb000
Creating 1 MTD partitions on "RAM":
0x00000000-0x000fb000 : "ROMfs"
uclinux[mtd]: set ROMfs to be root filesystem index=5
TCP cubic registered
VFS: Mounted root (cramfs filesystem) readonly.
Freeing unused kernel memory: 84k freed
Mounting proc:
Mounting var:
Populating /var:
u
It seems it stopped at the "Running local start scripts." I am not familar to Linux so can anyone possibly tell what hardware problem/mistake I possibly made which results the failure of the booting up of my Linux?
Thx
linnj
You may want to post this to a more specific group for Petalinux.  I don't use it so I can't help.  In general this forum is for open source Linux from Xilinx rather than a specific distribution like Petalinux.
