03-31-2015 02:54 AM
Sir/mam
I am using petalinux 2014.4 on Ubuntu platform with zc-706 board. I am trying to boot the board by tftp server, for that I am referring ug1144. I set server ip and board ip address by following commands………
1- Set serverip <server_ip address>
2- Set ipaddr <board_ipadd>
But when I run “ run netboot” command following error is coming :::::::::::::
Gem.e000b000:7 is connected to Gem.e000b000. Reconnecting to Gem.e000b000
Gem.e000b000 waiting for PHY auto negotiation to complete……………..Timeout
Gem.e000b000:no link.
Plzz help me out of this problem ……
04-14-2015 01:19 PM
Are the link lights on the 706 responding properly? That is, does it look electrically like you have a valid link?
04-16-2015 02:56 AM
04-21-2015 10:38 PM
Sir,
Prebuilt images for 2014.4/zc-706 is also not woking. When I simply boot by jtag cable by the command “petalinux-boot –jtag –prebuilt 3” then it simply ask me to enter root login and password and in this mode board and pc ping each other and application runs. but when I enter in U-BOOT mode board and pc don,t ping each other . below are the enviournment variable I have print…..
and how can i check the GEMO configuration in fsbl....
autoload=yes
baudrate=115200
boot_img=BOOT.BIN
bootcmd= run default_bootcmd
bootdelay=4
bootenvsize=0x20000
bootenvstart=0xe00000
clobstart=0x01000000
console=console=ttyPS0,115200
cp_kernel2ram=mmcinfo && fatload mmc 0 ${netstart} ${kernel_img}
default_bootcmd=run cp_kernel2ram && bootm ${netstart}
dtb_img=system.dtb
dtbnetstart=0x02800000
eraseenv=sf probe 0 && sf erase ${bootenvstart} ${bootenvsize}
ethact=Gem.e000b000
ethaddr=00:0a:35:00:40:19
fault=echo ${img} image size is greater than allocated place - partition ${img}D
hostname=Xilinx-ZC706-2014_4
install_boot=mmcinfo && fatwrite mmc 0 ${clobstart} ${boot_img} ${filesize}
install_jffs2=sf probe 0 && sf erase ${jffs2start} ${jffs2size} && sf write ${c}
install_kernel=mmcinfo && fatwrite mmc 0 ${clobstart} ${kernel_img} ${filesize}
ipaddr=192.168.1.10
jffs2_img=rootfs.jffs2
kernel_img=image.ub
load_boot=tftp ${clobstart} ${boot_img}
load_dtb=tftp ${clobstart} ${dtb_img}
load_jffs2=tftp ${clobstart} ${jffs2_img}
load_kernel=tftp ${clobstart} ${kernel_img}
loadaddr=0x01000000
nc=setenv stdout nc;setenv stdin nc;
netboot=tftp ${netstart} ${kernel_img} && bootm
netstart=0x01000000
psserial0=setenv stdout ttyPS0;setenv stdin ttyPS0
sd_update_dtb=echo Updating dtb from SD; mmcinfo && fatload mmc 0:1 ${clobstartb
sd_update_jffs2=echo Updating jffs2 from SD; mmcinfo && fatload mmc 0:1 ${clobs2
sdboot=echo boot Petalinux; mmcinfo && fatload mmc 0 ${netstart} ${kernel_img}
serial=setenv stdout serial;setenv stdin serial
serverip=192.168.1.20
test_crc=if imi ${clobstart}; then run test_img; else echo ${img} Bad CRC - ${ii
test_img=setenv var "if test ${filesize} -gt ${psize}; then run fault; else runr
update_boot=setenv img boot; setenv psize ${bootsize}; setenv installcmd "instad
update_dtb=setenv img dtb; setenv psize ${dtbsize}; setenv installcmd "install_d
update_jffs2=setenv img jffs2; setenv psize ${jffs2size}; setenv installcmd "ind
update_kernel=setenv img kernel; setenv psize ${kernelsize}; setenv installcmd d
Environment size: 2599/131068 bytes
U-Boot-PetaLinux>
04-21-2015 10:41 PM
sir
in simple boot mode by jtrag cable board and pc ping each other and application runs/
but in u-boot mode board and pc dont ping each other.............
even when i boot by sd card both are ping each other....
