petalinux v2017.1 kernel menuconfig ccache error
I have just installed petalinux v2017.1, I have created a new project, imported the hardware description file, configure rootfs, but when I try to configure the kernel through
petalinux-config -c kernel
I receive this error :
 HOSTCC  scripts/basic/fixdep
ccache: error: Could not find compiler "gcc" in PATH
and there is no menuconfig
what could be the cause of the problem?
Re: petalinux v2017.1 kernel menuconfig ccache error
finally I have found the solution
with previous version of petalinux and SDK I have to add to the settings.sh script :
unset GNOME_DESKTOP_SESSION_ID
otherwise SDK would have crashed.
I don't need it anymore with v2017.1
in file <$PETALINUX_DIR>/components/yocto/source/arm/environment-setup-cortexa9hf-neon-xilinx-linux-gnueabi
I have found the settings for PATH and CCACHE_PATH but they are pointing to a non-existing folder tmp/sysroots/x86_64-linux/ :
export PATH=/opt/Xilinx2017.1/petalinux-v2017.1-final/components/yocto/source/arm/tmp/sysroots/x86_64-linux/usr/bin:/opt/Xilinx2017.1/petalinux-v2017.1-final/components/yocto/source/arm/tmp/sysroots/x86_64-linux/usr/sbin:/opt/Xilinx2017.1/petalinux-v2017.1-final/components/yocto/source/arm/tmp/sysroots/x86_64-linux/bin:/opt/Xilinx2017.1/petalinux-v2017.1-final/components/yocto/source/arm/tmp/sysroots/x86_64-linux/sbin:/opt/Xilinx2017.1/petalinux-v2017.1-final/components/yocto/source/arm/tmp/sysroots/x86_64-linux/usr/bin/../x86_64-petalinux-linux/bin:/opt/Xilinx2017.1/petalinux-v2017.1-final/components/yocto/source/arm/tmp/sysroots/x86_64-linux/usr/bin/arm-xilinx-linux-gnueabi:/opt/Xilinx2017.1/petalinux-v2017.1-final/components/yocto/source/arm/tmp/sysroots/x86_64-linux/usr/bin/arm-xilinx-linux-uclibc:/opt/Xilinx2017.1/petalinux-v2017.1-final/components/yocto/source/arm/tmp/sysroots/x86_64-linux/usr/bin/arm-xilinx-linux-musl:$PATH
export CCACHE_PATH=/opt/Xilinx2017.1/petalinux-v2017.1-final/components/yocto/source/arm/tmp/sysroots/x86_64-linux/usr/bin:/opt/Xilinx2017.1/petalinux-v2017.1-final/components/yocto/source/arm/tmp/sysroots/x86_64-linux/usr/bin/../x86_64-petalinux-linux/bin:/opt/Xilinx2017.1/petalinux-v2017.1-final/components/yocto/source/arm/tmp/sysroots/x86_64-linux/usr/bin/arm-xilinx-linux-gnueabi:/opt/Xilinx2017.1/petalinux-v2017.1-final/components/yocto/source/arm/tmp/sysroots/x86_64-linux/usr/bin/arm-xilinx-linux-uclibc:/opt/Xilinx2017.1/petalinux-v2017.1-final/components/yocto/source/arm/tmp/sysroots/x86_64-linux/usr/bin/arm-xilinx-linux-musl:$CCACHE_PATH
more,
in my <project-dir>/project-spec/meta-user/ folder, there is no recipes-kernel
hi,
have you download sstate cache   form xilinx:https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/embedded-design-tools.html
 and config this configure:  YOCTO_LOCAL_SSTATE_FEEDS_URL。
using petaconfig  to config it:
-> Yocto Settings
      -> Local sstate feeds settings
BRs,
yes I did.
I get the error when do_menuconfig is called. I wonder why ccache is looking for "gcc" as in PATH from settings.sh all the compiler in /tools/linux-i386 have been exported. shouldn't be look for "gcc-arm-linux-gnueabi"?
there is no error if I issue the command
petalinux-config -c kernel --defconfig xilinx_zynq_defconfig
but still no menuconfig is open
