lzhao
petalinux-v2018.3-final-installer install error
I am installing petalinux-v2018.3-final-installer on ubuntu 16.04.1. I've created a petalinux folder, and I tried:
./petalinux-v2018.3-final-installer.run ~/petalinux/
Following is the error messge I got.
./petalinux-v2018.3-final-installer.run: line 52: /harddisk1/xxxx/petalinux/petalinux_installation_log: Permission denied
tee: /harddisk1/xxxx/petalinux/petalinux_installation_log: Permission denied
INFO: Checking installation environment requirements...
Please refer to the PetaLinux Tools Installation Guide.
Check the troubleshooting guide at the end of that manual, and if you are
unable to resolve the issue please contact customer support with file:
./petalinux-v2018.3-final-installer.run: line 139: /tmp/tmp.BRPcJQCjQP/petalinux-env-check: No such file or directory
ERROR: Failed to extract Petalinux installer...
I saw someone got into the same issue. https://askubuntu.com/questions/1104868/petalinux-v2018-2-installation-error?newreg=044779edc0f549ac84fcfa2fd2121716
But it does not work for me, I still got the same error message.
Did I miss something? Thanks!
aravindb
HI @lzhao
Try running ls -l  /home/username/petalinux and if it is set to root, you  need to change to username using below command.
sudo chown -R  <owner>:<owner> /home/chenziyun/petalinux
./petalinux-v2018.2-final-installer.run /home/username/petalinux
Thanks & regards
Aravind
lzhao
Hi Aravind,
Thanks for the response. I ended up using following command to change the permission of the petalinux_installation_log file. And that solved my problem.
sudo chmod 777 petalinux_installation_log
LZ
