petalinux2019.1 petalinux-build error
When I did petalinux-build on petalinux 2109.1, the following error occurred. Why?
sd@sd-HP-Z440-Workstation:~/TRD_HOME/apu/vcu_petalinux_bsp/xilinx-vcu-trd-zcu106-v2019.1-final$ petalinux-build
[INFO] building project
[INFO] sourcing bitbake
[INFO] generating user layers
INFO: bitbake petalinux-user-image
Loading cache: 100% |#########################################################################################| Time: 0:00:00
Loaded 3814 entries from dependency cache.
Parsing recipes: 100% |#######################################################################################| Time: 0:00:03
Parsing of 2780 .bb files complete (2778 cached, 2 parsed). 3815 targets, 150 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |####################################################################################| Time: 0:00:09
Checking sstate mirror object availability: 100% |############################################################| Time: 0:00:00
Sstate summary: Wanted 326 Found 231 Missed 190 Current 1912 (70% match, 95% complete)
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: petalinux-user-image-1.0-r0 do_rootfs: The postinstall intercept hook 'update_gtk_immodules_cache' failed, details in /home/sd/TRD_HOME/apu/vcu_petalinux_bsp/xilinx-vcu-trd-zcu106-v2019.1-final/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/temp/log.do_rootfs
ERROR: petalinux-user-image-1.0-r0 do_rootfs: Function failed: do_rootfs
ERROR: Logfile of failure stored in: /home/sd/TRD_HOME/apu/vcu_petalinux_bsp/xilinx-vcu-trd-zcu106-v2019.1-final/build/tmp/work/plnx_zynqmp-xilinx-linux/petalinux-user-image/1.0-r0/temp/log.do_rootfs.28949
ERROR: Task (/home/sd/TRD_HOME/apu/vcu_petalinux_bsp/xilinx-vcu-trd-zcu106-v2019.1-final/project-spec/meta-plnx-generated/recipes-core/images/petalinux-user-image.bb:do_rootfs) failed with exit code '1'
NOTE: Tasks Summary: Attempted 7009 tasks of which 7008 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build project
Mentor
Mentor
Re: petalinux2019.1 petalinux-build error
Hi @shengdishd
Did you follow VCU TRD 2019.1 in Xilinx Wiki ?
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/112230447/Zynq+UltraScale+MPSoC+VCU+TRD+2019.1
I already rebuild VCU TRD 2019.1 and it sucessed.
Best regards,
Hi@watari
I follow VCU TRD 2019.1 in Xilinx Wiki. My computer system is  Ubuntu Linux 18.04.1 (64-bit).
What system is your computer?
Mentor
Mentor
Hi @shengdishd
I rebuild this TRD via petalinux on CentOS 7.5 on docker.
Best regards,
Hi@watari
Do you have VIVADO installed on your computer?
Mentor
Mentor
Hi @shengdishd
Yes. I already have prepared the followings.
1. Using Docker
Already installed petalinux 2019.1 on CentOS 7.5 on Docker.
Also I can use Vivado2019.1, if necessary.
2. Using Host
Already installed petalinux 2019.1 and VivadoHLS 20191 on CentOS 7.
However, I usually use petalinux on Docker. Because I'd like to use it on pure CentOS (without unnecessary package).
Best regards,
Have you run petalinux-build --sdk? Have error under?
ERROR: qt3d-5.11.3+gitAUTOINC+cd3e621ccf-r0 do_compile: oe_runmake failed
ERROR: qt3d-5.11.3+gitAUTOINC+cd3e621ccf-r0 do_compile: Function failed: do_compile (log file is located at /home/sd-z440/TRD_HOME/apu/vcu_petalinux_bsp/xilinx-vcu-trd-zcu106-v2019.1-final/build/tmp/work/aarch64-xilinx-linux/qt3d/5.11.3+gitAUTOINC+cd3e621ccf-r0/temp/log.do_compile.14367)
ERROR: Logfile of failure stored in: /home/sd-z440/TRD_HOME/apu/vcu_petalinux_bsp/xilinx-vcu-trd-zcu106-v2019.1-final/build/tmp/work/aarch64-xilinx-linux/qt3d/5.11.3+gitAUTOINC+cd3e621ccf-r0/temp/log.do_compile.14367
I encounter the exact same issue on CentOS Linux release 7.6.1810 (Core).
Do you have found a fix, or you just have worked around by using another distro ?
jeremy
Mentor
Mentor
Hi @shengdishd , jeremy@easii-ic
Sorry for my late reply.
I suggest you to make sure the followings.
- Real memory size. (At lease need 8GB)
- Swap memory size. (Same as real memory size, as possible as)
Best regards,
