Observer ilkras
please help to configure the build system (libmali-xlnx-r7p0-00rel0-r0 retrieval problem)
Hi.
I am completely new to petalinux and to yocto and maybe my problem has a very simple solution (hopefully).
I installed petalinux tools 2017.2. Configured rootfs and built. The build failed with the following:
ERROR: libmali-xlnx-r7p0-00rel0-r0 do_fetch: Fetcher failure for URL: 'git://gitenterprise.xilinx.com/Graphics/mali400-xlnx-userspace.git;protocol=https;branch=master'. Unable to fetch URL from any source.
ERROR: libmali-xlnx-r7p0-00rel0-r0 do_fetch: Function failed: base_do_fetch
There are numerous questions on this issue and answers provided do not lead to the successful build.
I found that there is petalinux-v2017.2-open_components.tar.gz available for download from XIlinx site and that file contains libmali-xlnx-r7p0-00rel0-r0.tar.gz among many others. May me all or most of the needed components resides there.
Now the question:
How can I configure the petalinux tools (or just Yocto) to use this archive before trying to download the needed package from the network (this can also improve greatly the speed of the build)?
Ilya
Observer kallensf
Re: please help to configure the build system (libmali-xlnx-r7p0-00rel0-r0 retrieval problem)
If you follow the above AR and still have fetcher failure, try to clean up any previous build state:
petalinux-build -x distclean
petalinux-build -x mrproper
Regenerate local.conf:
petalinux-config
Then edit local.conf as described in the above AR.
This is a known issue, please see the AR below:
https://www.xilinx.com/support/answers/69564.html
Observer kallensf
petalinux-config
