powerpc xilix-linux with RAM mapped other than zero.
Hi all,
I've a system design with SDRAM mapped at 0xf8000000 rather than at 0. what are the changes i should make to successfully boot a kernel..?
my design with SDRAM at 0 (64MB) is working file with xilinx git line (2.6.27).  i was using 'make simpleImage.xilinx (where xilinx.dts is my device tree file)
i tried to change the link_address in arch/powerpc/boot/wrapper from 0x400000 to 0xf4000000. when i analysed the dump with step mode in xmd, it fails in platform_init() function in arch/powerpc/boot/simpleboot.c
may be at
/* Only interested in memory based at 0 */
 for (i = 0; i < *na; i++)
  if (*reg++ != 0)
   fatal("Memory range is not based at address 0\n");
can anyone tell what are the changes i shoud do if my memory ranges from 0xf8000000 to 0xfbffffff..? (64MB)
Device tree file is attached
Thanks in advance,
Sumesh.
I don't remember, but I remember this topic has been discussed on linuxppc-dev mailing list out in the community.
I would search there.  That's pretty custom so I don't tend to do that.
John
