vidyut
problem in running c++ application on zedboard!!
Dear colleague,
I have written simple hallo_world program in c++  sdk and trying to execute on zedboard which is running linux----for unknow reason i cannot do it....no error is seen...!!! What am I doing wrong?
I will glad if you could help me here!!
regards
radheys
Please take a look at this post:
http://forums.xilinx.com/t5/Embedded-Linux/arm-xilinx-linux-gnueabi-g/td-p/317537
You have to copy libstdc++.so into target /lib directory.
Additonally if you dont want to edit the ramdisk , copy libc directory to the SD card and set LD_LIBRARY_PATH before running the application.
export  LD_LIBRARY_PATH=/mnt/libc:$LD_LIBRARY_PATH
./hello_world
Hope it works.
-Radhey
radheys
I assume compiler invoked for your project is :
arm-xilinx-linux-gnueabi-g++
Which tool version are you using?
Have you done any modification to ramdisk image?
Check out zynq release images @http://www.wiki.xilinx.com/Zynq+Releases
Hope it helps.
-Radhey
vidyut
dear Radhey
Many thanks for your reply...
for your information  I am pasting the copy of commnad invoked by sdk14.4
'Building file: ../src/main.cc'
'Invoking: ARM g++ compiler'
arm-xilinx-eabi-g++ -Wall -O0 -g3 -c -fmessage-length=0 -MT"src/main.o" -I../../bitset1_bsp/ps7_cortexa9_0/include -MMD -MP -MF"src/main.d" -MT"src/main.d" -o "src/main.o" "../src/main.cc"
'Finished building: ../src/main.cc'
'Building target: bitset1.elf'
'Invoking: ARM g++ linker'
arm-xilinx-eabi-g++ -Wl,-T -Wl,../src/lscript.ld -L../../bitset1_bsp/ps7_cortexa9_0/lib -o "bitset1.elf" ./src/main.o -Wl,--start-group,-lxil,-lgcc,-lc,-lstdc++,--end-group
'Finished building target: bitset1.elf'
'Invoking: ARM Print Size'
arm-xilinx-eabi-size bitset1.elf |tee "bitset1.elf.size"
text data bss dec hex filename
476372 2556 31368 510296 7c958 bitset1.elf
'Finished building: bitset1.elf.size'
I am using latest release of zync Zynq 2014.4 Release (latest)
vidyut
Vivado 2014.4.1
radheys
Hi ,
From your SDK console log it appears that you are creating/compiling a standalone c++ application.
Here is the option for creating c++ application for Linux platform.
File -> Application project
In OS Platform menu - > select Linux and then build the application.
Hope it helps.
-Radhey
vidyut
dear Radhey,
Many thanks for your message!
my c++ application for standalone version is working fine.. problem is eveident when i try on my linux machine.
I have made the project using OS:linux...but problem is something else !!
something related to libstdc++.so.6. I saw many post on this forum which are marked solved for not working any more for me...I think this is a kind of problem which is very common and need to be fixed.
I copied libstdc++.so.6 from my SDK/2014.4/lib/lnx32.o/  to ramdisk ...but problem still persist.
I will gratful if you could help me here!!
radheys
./hello_world
Hope it works.
-Radhey
vidyut
Dear Radhey!!
Many thank for the files!! In
it is really fixed  now !!!
I will mention how I actually did it.
unzip the file into the /lib/ folder of  ramdisk (in such a way that it still recognise that file are linked, sometime simply copying does not show it!!)
see this
and re-create your ramdisk.
Done!!
Many thanks for these files and your concern!!!
Many Regards
radheys
Good to hear that issue is resolved!!!
-Radhey
vidyut
Dear radhey!!
I would say to please update the new release image with these files. As after modification you neeed to update your u-boot also.
I would suggest please update the new release with these files.
