johnblackxilinx2
problem on u-boot ( "Synchronous Abort" handler, esr 0x02000000 )
Hi all.
I have 3 custom boards (all of them are similar) based on zynqmp. i use vivado and petalinux 2019.1.
I built an image in petalinux and tested on three boards from SDcard. one of them at boot time report these:
Xilinx Zynq MP First Stage Boot Loader
Release 2019.1 Dec 9 2019 - 10:19:11
NOTICE: ATF running on XCZU5EG/silicon v4/RTL5.1 at 0xfffea000
NOTICE: BL31: Secure code at 0x0
NOTICE: BL31: Non secure code at 0x8000000
NOTICE: BL31: v2.0(release):xilinx-v2018.3-720-g80d1c790
NOTICE: BL31: Built : 10:19:36, Dec 9 2019
PMUFW: v1.1
U-Boot 2019.01 (Dec 09 2019 - 10:46:23 +0000)
Board: Xilinx ZynqMP
DRAM: 4 GiB
elr: 000000000806df00 lr : 0000000008000c88 (reloc)
elr: 000000007ff73f00 lr : 000000007ff06c88
x0 : 000000007ffe0000 x1 : 0000000000000000
x2 : 0000000000000000 x3 : 000000007ffe1000
x4 : 0000000000000000 x5 : 0000000000000000
x6 : ffffffffffffffff x7 : 0000000000000000
x8 : 0000000000000000 x9 : 0000000000000008
x10: 000000000a200023 x11: 0000000000000002
x12: 0000000000000002 x13: 00000000000071a8
x14: 00000000000f7c1c x15: 000000007ff07224
x16: 0000000000000000 x17: 0000000000000000
x18: 000000007de85de8 x19: 000000007ffe0000
x20: 0000000000020000 x21: 0000000000000000
x22: 0000000000000000 x23: 0000000000000000
x24: 000000007ff98000 x25: 00000000fffffff7
x26: 0000000000000000 x27: 0000000000000000
x28: 0000000000000000 x29: 000000007de7be30
Resetting CPU ...
but this image run correctlly on others; boot the kernel and rootfs.
i checked HW several times but I can find source of this exception error!.
it related to HW bug? or it needed some modification in image and configuration?
anyone can help me?
watari
Hi @johnblackxilinx2
You must use same version to build u-boot, ATF, PMUFW, u-boot and linux kernel.
Best regards,
johnblackxilinx2
Hi, thanks for reply.
I used same version for all.
but i received exception error!
watari
Is it true ?
>PMUFW: v1.1
It seems different version...
Best regards,
johnblackxilinx2
thanks for reply, but i rebuilt it again and received:
Release 2019.1 Jan 6 2020 - 08:13:26
NOTICE: BL31: v2.0(release):xilinx-v2019.1
NOTICE: BL31: Built : 05:00:06, Jan 7 2020
PMUFW: v1.1
U-Boot 2019.01 (Jan 07 2020 - 05:00:55 +0000)
DRAM: 4 GiB
Resetting CPU ...
I want to know where is the source of this exception.
watari
Would you share whole boot log message or memory map of uImage ?
I'd like to investigate the route cause with EABI information...
Best regards,
sandeepg
Hi @johnblackxilinx2 ,
From you logs it's hagning at  elr: 000000000806df00 now you need to debug the u-boot.
  1. Save the u-boot build artifacts by adding below variable in project-spec/meta-user/conf/petalinuxbsp.conf
    RM_WORK_EXCLUDE += "u-boot-xlnx"
  2. Clean u-boot sstate and rebuild the u-boot
    $ petalinux-build -c u-boot-xlnx -x cleansstate
  3. To debug more on u-boot add this below configs in project-spec/meta-user/recipes-bsp/u-boot/files/platform-top.h
    #define DEBUG
    #define CONFIG_SYS_INIT_RAM_SIZE 0x2000
    #define CONFIG_CMD_REGINFO
    #define CONFIG_PANIC_HANG
  4. Now you will have a u-boot file
    $ build/tmp/work/plnx_aarch64-xilinx-linux/u-boot-xlnx/v2019.01-xilinx-v2019.1+gitAUTOINC+<commit_id>-r0/build/u-boot
  5. Open this u-boot file and check for address 000000000806df00 it will tell you which code is causing the problem.
Sandeep
neutrinoxy
Hi @sandeepg,
I have the same issue after it tries to start the kernel. So I tried to follow your instructions in order to get the u-boot file using the CONFIG_CMD_REGINFO flag. However, the build fails, and the log file contains no error except the last one:
ERROR: oe_runmake failed
 So, I have no means for debugging this synchronous abort error. Do you have an idea about why this recipe fails to build?
Best regards.
stephenm
