08-06-2017 12:07 PM
I followed this tutorial: https://www.instructables.com/id/Embedded-Linux-Tutorial-Zybo/
but now I'm stuck,
when I enter: make CROSS_COMPILE=arm-xilinx-linux-gnueabi-zynq_ZYBO_config
I get the error: System not configured - see README
I have no idea why that occurs, I'm using ubuntu 16 with Vivado Web+SDK 16.4 its a new VM so I have only the xilinx software installed, do i need to install anything else may be?
08-06-2017 01:06 PM
Hey cto@qlt
The problem is very likely a missing space in your command:
This should actually be:
make CROSS_COMPILE=arm-xilinx-linux-gnueabi- zynq_zybo_config
Also note that lower and upper case is important on Unix/Linux systems.
Hope it helps,
Herbert
08-06-2017 01:06 PM
Hey cto@qlt
Hope it helps,
Herbert
08-06-2017 01:41 PM
That solved that issue.
now I have a new one:
user@ubuntu:~/DIGILENT_LINUX/u-boot-Digilent-Dev$ make CROSS_COMPILE=arm-xilinx-linux-gnueabi- zynq_zybo_config Configuring for zynq_zybo board... trax@ubuntu:~/DIGILENT_LINUX/u-boot-Digilent-Dev$ make CROSS_COMPILE=arm-xilinx-linux-gnueabi- /bin/bash: /opt/Xilinx/SDK/2016.4/gnu/arm/lin/bin/arm-xilinx-linux-gnueabi-gcc: No such file or directory /bin/bash: /opt/Xilinx/SDK/2016.4/gnu/arm/lin/bin/arm-xilinx-linux-gnueabi-gcc: No such file or directory dirname: missing operand Try 'dirname --help' for more information. Generating include/autoconf.mk /bin/bash: line 2: /opt/Xilinx/SDK/2016.4/gnu/arm/lin/bin/arm-xilinx-linux-gnueabi-gcc: No such file or directory Generating include/autoconf.mk.dep /bin/bash: line 2: /opt/Xilinx/SDK/2016.4/gnu/arm/lin/bin/arm-xilinx-linux-gnueabi-gcc: No such file or directory /bin/bash: /opt/Xilinx/SDK/2016.4/gnu/arm/lin/bin/arm-xilinx-linux-gnueabi-gcc: No such file or directory /bin/bash: /opt/Xilinx/SDK/2016.4/gnu/arm/lin/bin/arm-xilinx-linux-gnueabi-ld: No such file or directory Generating include/spl-autoconf.mk /bin/bash: line 2: /opt/Xilinx/SDK/2016.4/gnu/arm/lin/bin/arm-xilinx-linux-gnueabi-gcc: No such file or directory Generating include/tpl-autoconf.mk /bin/bash: line 2: /opt/Xilinx/SDK/2016.4/gnu/arm/lin/bin/arm-xilinx-linux-gnueabi-gcc: No such file or directory arm-xilinx-linux-gnueabi-gcc -DDO_DEPS_ONLY \ -g -Os -ffunction-sections -fdata-sections -fno-common -ffixed-r9 -fno-strict-aliasing -mno-unaligned-access -mfpu=neon -D__KERNEL__ -I/home/trax/DIGILENT_LINUX/u-boot-Digilent-Dev/include -I/home/trax/DIGILENT_LINUX/u-boot-Digilent-Dev/arch/arm/include -fno-builtin -ffreestanding -nostdinc -isystem -pipe -DCONFIG_ARM -D__ARM__ -march=armv5 -Wall -Wstrict-prototypes \ -o lib/asm-offsets.s lib/asm-offsets.c -c -S /bin/bash: /opt/Xilinx/SDK/2016.4/gnu/arm/lin/bin/arm-xilinx-linux-gnueabi-gcc: No such file or directory Makefile:694: recipe for target 'lib/asm-offsets.s' failed make: *** [lib/asm-offsets.s] Error 127 user@ubuntu:~/DIGILENT_LINUX/u-boot-Digilent-Dev$
but the fiel is there:
user@ubuntu:~/DIGILENT_LINUX/u-boot-Digilent-Dev$ ls -l /opt/Xilinx/SDK/2016.4/gnu/arm/lin/bin/arm-xilinx-linux-gnueabi-gcc
-rwxr-xr-x 1 root root 735360 Oct 26 2016 /opt/Xilinx/SDK/2016.4/gnu/arm/lin/bin/arm-xilinx-linux-gnueabi-gcc
its listed, and the file has execute permission, but when I try to execute it i get the no such file error wtf :/
any ideas how that happens?
08-06-2017 02:15 PM
cto@qlt If it solved the issue, it is correct etiquette to give @hpoetzl the solution, then open a new request. That will keep new answers coming fast your way.
Just a few of the respondents here are Xilinx employees. Mostly are here just for the dopamine kick of a kudos and solutions accepted (my case anyway).
Keep that in mind.
08-06-2017 05:35 PM
Hey cto@qlt
The executable in question is a dynamically linked binary, which means that it depends on some libraries.
If one of the libraries is missing, you will get 'No such file or directory'.
Double check the library dependencies with:
ldd /opt/Xilinx/SDK/2016.4/gnu/arm/lin/bin/arm-xilinx-linux-gnueabi-gcc
And see if the listed libraries are properly configured.
Hope this helps,
Herbert
08-06-2017 11:53 PM
@ubuntu:~/DIGILENT_LINUX/u-boot-Digilent-Dev$ ldd /opt/Xilinx/SDK/2016.4/gnu/arm/lin/bin/arm-xilinx-linux-gnueabi-gcc not a dynamic executable
wtf?
should I install the xilinx software again or what else should I try?
I have also an other problem i cant start the SDK, when I go on start SDK nothing happens
08-07-2017 12:04 AM
cto@qlt Can you do a
file /opt/Xilinx/SDK/2016.4/gnu/arm/lin/bin/arm-xilinx-linux-gnueabi-gcc
In my install it is a ELF 32-bit LSB executable, dynamically linked.
08-07-2017 03:09 AM
Ah its 32 bit, that explains a lot...
after installing support for 32 bit executables the build process works Thanks :-)
