psu_init_gpl.c for ZCU102 rev1.1
I'm trying to build a custom Linux for a board ZCU102 rev1.1, using Buildroot and the oficial reposiroty of Xilinx (https://github.com/Xilinx).
This tool uses https://github.com/Xilinx/u-boot-xlnx but it's not available the support for ZCU102 rev1.1 (only for revA, revB and rev1.0).
Can anyone provides me the file psu_init_gpl.c for rev1.1? I think that it's the difference between both.
Re: psu_init_gpl.c for ZCU102 rev1.1
If you build  Vivado design for this rev of the board, and export to SDK/Vitis then the psu_init files will be in the HDF/XSA file
Vivado hasn't this rev of the board (only rev1.0), neither xilinx's SDK.
Supposedly, the difference between rev1.0 and rev1.1 is only mechanical.
Using the offical xilinx's repository (linux-xlnx, U-boot-xlnx) and the official ATF's repository (arm-trusted-firmware), the compilation (Buildroot) that does work for rev1.0 but doesn't work for rev1.1.
Any suggestions?
What doesn't work? Does it boot? Do you have a boot log?
The board doesn't boot. The log is simple:
<debug_uart> Debug uart enabled
### ERROR ### Please RESET the board ###
I saw yesterday this post: https://www.xilinx.com/support/answers/72113.html and, my board has the same faillure and one of the serial numbers with the newer DIMMs (0432055-05).
The post proposes the solution: To work around this issue, you can replace the FSBL source code files with the attached .c/.h files in 72113-files.zip.But I don't find this files (.c/.h) in Petalinux or Vivado tool.
