qemu booting kernel failed 2017.4
I followed the page and test "Using SD for Boot".
http://www.wiki.xilinx.com/Xilinx+QEMU+Kernel+boot
However, I got stuck while running ARM instance as below, could you please help me out? thanks.
I did against pre_built images 2017.4. and using "petalinux_2017_4/tools/linux-i386/petalinux/bin/qemu-system-aarch64" and "/petalinux_2017_4/tools/linux-i386/petalinux/bin/qemu-system-microblazeel".
Hi David
I have tried myself again at our end and is booting fine. Here are the steps followed:-
1. Create BOOT.BIN using petalinux-package command (make sure to have attached FSBL passed to this command while creating BOOT.BIN)
petalinux-package --boot --fsbl zynqmp_fsbl.elf --pmufw pre-built/linux/images/pmufw.elf --atf pre-built/linux/images/bl31.elf --u-boot pre-built/linux/images/u-boot.elf
2. dd if=/dev/zero of=qemu_sd.img bs=128M count=1
3. mkfs.vfat -F 32 qemu_sd.img
4. mcopy -i qemu_sd.img BOOT.BIN ::/
5. mcopy -i qemu_sd.img pre-built/linux/images/image.ub ::/
6. mcopy -i qemu_sd.img pre-built/linux/images/system.dtb ::/
This creates final qemu_sd.img and used the same ARM & PMU instances to launch QEMU boot.
Attached FSBL for your reference. If you want, I will share qemu_sd.img too, but since this is of approx.120M I cant share it through forum or email.
Best Regards
Shabbir
BTW, I am working on Ubuntu 16.04.3 LTS.
Could you please share the command-line that you have passed in ARM instance? Did you try with the attached FSBL of wiki ?
Best Regards
Shabbir
Yes. I am using the attached FSBL.elf
ARM instance:
/petalinux_2017_4/tools/linux-i386/petalinux/bin/qemu-system-aarch64 -M arm-generic-fdt -nographic -dtb ./pre-built/linux/images/zynqmp-qemu-multiarch-arm.dtb -device loader,file=./pre-built/linux/images/zynqmp_fsbl.elf,cpu-num=0 -global xlnx,zynqmp-boot.cpu-num=0 -global xlnx,zynqmp-boot.use-pmufw=false -machine-path /tmp/ -gdb tcp::9001 -drive file=./pre-built/linux/images/qemu_sd.img,if=sd,format=raw,index=1 -boot mode=5 -m 4G
PMU instance:
petalinux_2017_4/tools/linux-i386/petalinux/bin/qemu-system-microblazeel -M microblaze-fdt -nographic -dtb ./pre-built/linux/images/zynqmp-qemu-multiarch-pmu.dtb -kernel ./pre-built/linux/images/pmu_rom_qemu_sha3.elf -device loader,file=./pre-built/linux/images/pmufw.elf -machine-path /tmp/ -gdb tcp::9005
Try passing the attached FSBL instead of prebuilt FSBL, as I am seeing in the below instance you are passing prebuilt fsbl image
Best Regards
Shabbir
Hi ,
I have already downloaded and replaced the prebuilt one.  The size is 164944 bytes.
Are you from Xilinx? Could you please try on your side? Thanks.
"Here are the steps to boot the Xilinx's ZynqMP based kernel through QEMU supported flash devices. These steps are validated against 2017.4 release version."
I trusted what you said above in that page. It would be better not to make us disappointed. Look forward to hearing from you.
David
Hi David
Best Regards
Shabbir
Hi Shabbirk,
