jrhtech
Voyager
Voyager
read-only filesystem fails for sysvinit inittab
 We have configured our rootfs to be read-only; however, I keep getting this error when creating the rootfs
The following packages could not be configured offline and rootfs is read-only: ['100-sysvinit-inittab']
We are using petalinx 2020.1.
I have tried setting
SERIAL_CONSOLES_CHECK_forcevariable = ""
in petalinuxbsp.conf but for some reason it never overrides the variable.   I can see in the recipe that if this was empty the failing function would work.   I tried setting SERIAL_CONSOLES_CHECK = "" in my own bbappend and still no luck.
Has anyone got this to work?
thanks,
jeff
