shairva
recipes are not being added
I have added one module recipe:
cp -r recipes-modules [My petalinux-project-v2019.1 path]/project-spec/meta-user
So now, this the module folder is located at:
[My petalinux-project-v2019.1 path]/project-spec/meta-user/recipes-modules/dpu
But then, when I perform
petalinux-config -c rootfs
I cannot enable the dpu because is not there!
Any idea why is happening that?
I can't even see the modules sections. Why the modules section is not there?
linux
aravindb
HI @shairva
Looks you have not created a module using this command "petalinux-create -t modules --name mymodule --enable"
Can you please follow the steps mentioned in ug1144 guide(Steps to Add Custom Modules)
1. Create a user module called mymodule in C
The new module recipe you created can be found in the <plnx-proj-root>/project-spec/
meta-user/recipes-modules/mymodule
2. Change to the newly created module directory.
 cd <plnx-proj-root>/project-spec/meta-user/recipes-modules/mymodule
3. rename your custom module with mymodule & copy  to recipes-modules folder
4. petalinux-build
Thanks & regards
Aravind
