relocate simpleImage to execute from flash
Hi guys,
did someone tried to execute the simple loader directly from flash?
Is it possible by changing the linkerscript or will I run in more problems doing this?
I just want to avoid copying the image around to safe some boot time.
tg
Re: relocate simpleImage to execute from flash
Why don't you run your simple image directly from internal block RAM (or memory cache block RAM) ?
If it is small enough it is possible.
Otherwise you may succeed changing the linker script only if there is no need of a driver to read/write from Flash, and you put your reset vector to the physical address of your Flash
Well, the simpleImage is approx. 1.5 to 2MB of size, this is definitely larger than fpga bram.
I've decided to write a small bootloader which is capable of booting a uImage. The device-tree will be stored in bram (dependent of the fpga image)
The bootloader will run directly from bram, and decompresses the kernel from flash to ram.
Ho ok I did not understand that your "simple loader" was the simpeImage.
That's the good way to do : put a small bootloader in BRAM. That's what I did too. However for me I think that the device-tree is stored inside the kernel, not in BRAM. I use a script from Xilinx to convert the simpleImage to a Flash friendly image
Rest regards
