repo init is now working
Hi ,
While running a below command , getting following error
repo init -u git://github.com/Xilinx/yocto-manifests.git -b rel-v2018.2
Error
2019/07/03 20:47:47 socat[5134] E getaddrinfo("myproxy.example.com", "NULL", {1,0,1,6}, {}): Name or service not known
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
Please help
Re: repo init is now working
You need to set the proxy up on your end. Have you done this?
Hi ,
after setting the proxy , its working fine . But while running bitbake command getting checksum mismatch error .
Please find the below logs
WARNING: gobject-introspection-native-1.52.1-r0 do_fetch: Checksum mismatch for local file /home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/downloads/gobject-introspection-1.52.1.tar.xz
Cleaning and trying again.
WARNING: gobject-introspection-native-1.52.1-r0 do_fetch: Renaming /home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/downloads/gobject-introspection-1.52.1.tar.xz to /home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/downloads/gobject-introspection-1.52.1.tar.xz_bad-checksum_ab1a53e57f3e1831d578a644b3ce3f99
WARNING: gobject-introspection-native-1.52.1-r0 do_fetch: Checksum failure encountered with premirror download of http://ftp.gnome.org/pub/GNOME/sources/gobject-introspection/1.52/gobject-introspection-1.52.1.tar.xz - will attempt other sources.
ERROR: libcomps-native-0.1.8+gitAUTOINC+01a4759894-r0 do_unpack: Fetcher failure: Fetch command export DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-mu4nOVLwON,guid=61806683b48305206b7bd24a5d1ccd4d"; export SSH_AGENT_PID="3117"; export SSH_AUTH_SOCK="/tmp/ssh-J3jKNQljzZwe/agent.3081"; export PATH="/home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/sources/core/scripts/native-intercept:/home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/tmp/sysroots-uninative/x86_64-linux/usr/bin:/home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/tmp/work/x86_64-linux/libcomps-native/0.1.8+gitAUTOINC+01a4759894-r0/recipe-sysroot-native/usr/bin/python3-native:/home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/sources/core/scripts:/home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/tmp/work/x86_64-linux/libcomps-native/0.1.8+gitAUTOINC+01a4759894-r0/recipe-sysroot-native/usr/bin/x86_64-linux:/home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/tmp/work/x86_64-linux/libcomps-native/0.1.8+gitAUTOINC+01a4759894-r0/recipe-sysroot-native/usr/bin:/home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/tmp/work/x86_64-linux/libcomps-native/0.1.8+gitAUTOINC+01a4759894-r0/recipe-sysroot-native/usr/sbin:/home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/tmp/work/x86_64-linux/libcomps-native/0.1.8+gitAUTOINC+01a4759894-r0/recipe-sysroot-native/usr/bin:/home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/tmp/work/x86_64-linux/libcomps-native/0.1.8+gitAUTOINC+01a4759894-r0/recipe-sysroot-native/sbin:/home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/tmp/work/x86_64-linux/libcomps-native/0.1.8+gitAUTOINC+01a4759894-r0/recipe-sysroot-native/bin:/home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/sources/core/bitbake/bin:/home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/tmp/hosttools"; export HOME="/home/pre-si-user2"; git -c core.fsyncobjectfiles=0 clone -s -n /home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/downloads/git2/github.com.rpm-software-management.libcomps.git/ /home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/tmp/work/x86_64-linux/libcomps-native/0.1.8+gitAUTOINC+01a4759894-r0/git/ failed with exit code 128, output:
fatal: repository '/home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/downloads/git2/github.com.rpm-software-management.libcomps.git/' does not exist
ERROR: libcomps-native-0.1.8+gitAUTOINC+01a4759894-r0 do_unpack: Function failed: base_do_unpack
ERROR: Logfile of failure stored in: /home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/tmp/work/x86_64-linux/libcomps-native/0.1.8+gitAUTOINC+01a4759894-r0/temp/log.do_unpack.12538
ERROR: Task (virtual:native:/home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/sources/core/meta/recipes-devtools/libcomps/libcomps_git.bb:do_unpack) failed with exit code '1'
WARNING: python3-iniparse-native-0.4-r0 do_fetch: Checksum mismatch for local file /home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/downloads/iniparse-0.4.tar.gz
WARNING: python3-iniparse-native-0.4-r0 do_fetch: Renaming /home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/downloads/iniparse-0.4.tar.gz to /home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/downloads/iniparse-0.4.tar.gz_bad-checksum_08d7319708564ca24c7e5e1bdf9159e2
WARNING: python3-iniparse-native-0.4-r0 do_fetch: Checksum failure encountered with premirror download of https://files.pythonhosted.org/packages/source/i/iniparse/iniparse-0.4.tar.gz - will attempt other sources.
WARNING: gobject-introspection-native-1.52.1-r0 do_fetch: Renaming /home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/downloads/gobject-introspection-1.52.1.tar.xz to /home/pre-si-user2/Desktop/Pax_Subsytem/Xilinx_ZCU_102/Yocto/build/downloads/gobject-introspection-1.52.1.tar.xz_bad-checksum_bd12506876c78ef54ced9fc613e61825
WARNING: gobject-introspection-native-1.52.1-r0 do_fetch: Checksum failure encountered with download of http://ftp.gnome.org/pub/GNOME/sources/gobject-introspection/1.52/gobject-introspection-1.52.1.tar.xz - will attempt other sources if available
NOTE: Tasks Summary: Attempted 1788 tasks of which 1780 didn't need to be rerun and 1 failed.
NOTE: Writing buildhistory
Summary: 1 task failed:
