yangkejian
request for petalinux 2013.10 license
When I create a project using petalinux2013.10, I get the following error.
ERROR: No valid PetaLinux features! Typical causes for this error are either that there is no license file or that license files, which were found, do not contain a valid license with the required feature.
I refer tohttps://forums.xilinx.com/t5/Embedded-Linux/Someone-has-used-Xilinx-newly-released-Petalinux-12-12-how-to/td-p/282708,  the same error How do I load license for PetaLinux 2013.10
