require the phsical addree to configure VDMA in linux (Hardware Accelerators )
hi,
   I have a question in Hardware Accelerators system.  In linux system,  if i use "pIni = (float*)sds_alloc(N*N);" to malloc a space, how could i get the corresponding phsical address to configure the destination address of VDMA? Or else, does has another way to slove the problem? thank you for your help!
Re: require the phsical addree to configure VDMA in linux (Hardware Accelerators )
@csuhuadong
Check out this article on TLDP.org
http://www.tldp.org/LDP/khg/HyperNews/get/devices/addrxlate.html
Basically
        #include <asm/io.h>
phys_addr = virt_to_phys(virt_addr); virt_addr = phys_to_virt(phys_addr);
However these are only accessible in kernel mode.
In user space you need to decode /proc/<PID>/pagemap and /proc/<PID>/maps.
Here is an explanation and code.
http://fivelinesofcode.blogspot.com/2014/03/how-to-translate-virtual-to-physical.html
