Participant tuan.nhanh
run FreeRTOS on ZCU104
I had a ZCU104 and I would like to run FreeRTOS on it. But I knew FreeRTOS only supports ZCU102.
So what should I do to run FreeRTOS on ZCU104. I am new to Xilinx kits.
回复: run FreeRTOS on ZCU104
@tuan.nhanh ,
If you are using HDMI subsystem IP, there are standalone drivers. They are include in SDK. Or you can find it in below link.
https://github.com/Xilinx/embeddedsw/tree/release-2018.3/XilinxProcessorIPLib/drivers/v_hdmitxss
If you have questions about HDMI driver, you can post your questions in Intellectual Property -> Video board.
@tuan.nhanh
May I know where you find the information that FreeRTOS only supports ZCU102?
AFAIK, FreeRTOS should be supported by all MPSoC devices.
You can create a Vivado project based on ZCU104, export HW to SDK, then in SDK, create an application project by selecting "OS Platform" to Freertos10_xilinx, then you could generate a FreeRTOS application example.
Sorry i am new to this so I do not know.
After several days, i can make FreeRTOS on ZCU104.
1. Where is the program store? (as i knew on MCU the app will be store on ROM but Xilinx is MCP)
2. Can I run FreeRTOS and display image to screen via HDMI port of ZCU104?
3. Does Xilinx have bootloader for FreeRTOS?
Hi @tuan.nhanh ,
Please refer below links to run FreeRTOS application uisng Xilinx SDK.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842141/FreeRTOS
https://www.freertos.org/RTOS-Xilinx-SDK-BSP.html
Best Regards
Kranthi
I got these links. But I can not find that whether Xilinx support Standalone library for HDMI or not? Could you please answer me soon because I am in urgent case.
@tuan.nhanh ,
My zcu104 will use FPGA doe another purpose so I can not use it for HDMI IP (sorry if i am wrong, i have no idea about HW and FPGA).
does Xilinx have another driver for HDMI?
FreeRTOS is going to work on ZC704 board using xilinx SDK where boot process is as regular Linux boot process
From Xilinx Technical solutions wiki page, can find out pre built Free RTOS images where it works directly, on top of that you cna modify freertos image adding your driver & load the same on board.
so Check the wiki pages building & loading FreeRtos image on the Zc702 or Zc704 board (Procedure is same) & same pgae provides prebuilt images using SD card.
One more question support boot loader for freertos:  no need of boot loader code (Like u-boot) seperately for Freerots , regular code (combo of boot code + rtos kernel )will take care of the same.
Thanks & Regards
Satish G
G Satish Kumar
