samick
sdhci_send_command: MMC: 1 busy timeout increasing to: 400 ms
I am using Xilinx UZ3EG board.  In QSPI boot,If we remove the sd card and boot then I see below timout errors and after that the boot continues. This timeout is adding extra 15 second delay in the boot up when sd card is not attached. Is there any solution to avoid this when sd card is not connected? ( Note: If the card is attached then there is no issue. we don't want to attach the card in QSPI boot)
MMC: sdhci_send_command: MMC: 1 busy timeout increasing to: 200 ms.
sdhci_send_command: MMC: 1 busy timeout increasing to: 400 ms.
sdhci_send_command: MMC: 1 busy timeout increasing to: 800 ms.
sdhci_send_command: MMC: 1 busy timeout increasing to: 1600 ms.
sdhci_send_command: MMC: 1 busy timeout increasing to: 3200 ms.
shabbirk
samick
fixed the issue
damon
Hi @samick,
How is it solved?
shabbirk
Hi @damon
Can you try applying these patch changes to u-boot source and see if that fixes the issue?
https://patchwork.ozlabs.org/patch/1118693/
https://patchwork.ozlabs.org/patch/1118690/
Best Regards
Shabbir
damon
Hi @shabbirk,
Which version of uboot?
shabbirk
Hi @damon
These patches are merged in 2019.1. If you want to apply for previous releases, you have to manually make these changes
damon
Hi @shabbirk,
Device tree need to change something?
shabbirk
Hi @damon
You can just try applying these patches without changing device tree
damon
Hi @shabbirk,
I saw the xilinx-v2019.1 u-boot in xilinx github (https://github.com/Xilinx/u-boot-xlnx/tree/xilinx-v2019.1)
It seems that the patch you provided does not have merge into xilinx-v2019.1 u-boot.
shabbirk
Hi @damon
Its already in master branch of u-boot, which can be applied on top of 2019.1. If you are using this version, try applying these two patches and let me know if this works
damon
Hi @shabbirk,
I checked xilinx u-boot master branch, it seems that patch still not merged.
For example:
https://github.com/Xilinx/u-boot-xlnx/blob/master/drivers/mmc/mmc-uclass.c#L123
Please help to check~
shabbirk
damon
Hi @shabbirk,
It can work now.
Thanks for your help.
