Participant btsavage
sem_open() Failed.(28) No space left on device
I'm running Linux on the Zynq, booting from an SD card.  My application creates a number of message queues and semaphores.  Near the end of initialization these resources  the following error appears:
I'm a bit confused about exactly which device is full?  I'm booting off a 32GB SD card that is partitioned by following the instructions on the Xilinx Wiki page.
So, is this the filesystem on the root partition of the SD card?  Memory?  Any help is greatly appreciated!
Re: sem_open() Failed.(28) No space left on device
sem_open() needs shared memory. Typically shared memory is mounted as tmpfs on /dev/shm, so it consumes RAM resources. Try 'df -h' to find out how many space is left on shared memory. However, it is strange that sem_open() returns ENOSPC, because it should return ENOMEM in such cases. But you might have different implementation.
Hope this helps a bit.
Best,
Stephan
Observer naveeng
For your error, there might also be the reasons like swap space, the system limit for the maximum number of semaphore sets (SEMMNI),or the system wide maximum number of semaphores (SEMMNS).
Can you please check the below things of your system?
For instance,
petalinux@petalinux:~$ cat /proc/sys/kernel/sem
250 32000 32 128
petalinux@petalinux:~$ cat /proc/sys/kernel/msgmni
24029
You can make changes to the above things by writing into sysctl.conf file under /etc directory. E.g. kernel.msgmax = 65536, kernel.msgmnb = 65536 etc
You can also search for specific element information of /proc/sys/kernel/* (e.g.sem) in proc manual page(man proc):
       /proc/sys/kernel/sem (since Linux 2.4)
              This file contains 4 numbers defining limits for System V IPC semaphores.  These fields are, in order:
              SEMMSL  The maximum semaphores per semaphore set.
              SEMMNS  A system-wide limit on the number of semaphores in all semaphore sets.
              SEMOPM  The maximum number of operations that may be specified in a semop(2) call.
              SEMMNI  A system-wide limit on the maximum number of semaphore identifiers.
      /proc/sys/kernel/msgmni (since Linux 2.4)
              This file defines the system-wide limit on the number of message queue identifiers.
Naveen
It appears that my application is using all the system resources. We have an 8MB rootfs, so I started down the path of making a larger 16MB rootfs yesterday (which is not  yet working.)  Am I headed down the wrong path?
As a side note, I made an empty rootfs 16MB in size (all per the Xilinx wiki instructions) and then copied the directories from my 8MB rootfs (stripped the header and mounted the ramdisk.image file.)  I then built a new device tree, adding the "ramdisk_size" parameter to the boot args.  What did I miss?
RAMDISK: gzip image found at block 0
mmc0: new high speed SDHC card at address aaaa
mmcblk0: mmc0:aaaa SS32G 29.7 GiB
 mmcblk0: p1 p2
List of all partitions:
0100           16384 ram0  (driver?)
0101           16384 ram1  (driver?)
0102           16384 ram2  (driver?)
0103           16384 ram3  (driver?)
0104           16384 ram4  (driver?)
0105           16384 ram5  (driver?)
0106           16384 ram6  (driver?)
0107           16384 ram7  (driver?)
0108           16384 ram8  (driver?)
0109           16384 ram9  (driver?)
010a           16384 ram10  (driver?)
010b           16384 ram11  (driver?)
010c           16384 ram12  (driver?)
010d           16384 ram13  (driver?)
010e           16384 ram14  (driver?)
010f           16384 ram15  (driver?)
b300        31166976 mmcblk0  driver: mmcblk
  b301          204800 mmcblk0p1 8a1a7f7a-01
  b302        30961152 mmcblk0p2 8a1a7f7a-02
No filesystem could mount root, tried:  ext3 ext2 ext4 vfat msdos
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
CPU1: stopping
CPU: 1 PID: 0 Comm: swapper/1 Not tainted 4.0.0-xilinx-00076-gdfc1bc8-dirty #7
Hardware name: Xilinx Zynq Platform
[<c001480c>] (unwind_backtrace) from [<c0010d4c>] (show_stack+0x10/0x14)
[<c0010d4c>] (show_stack) from [<c047e9b8>] (dump_stack+0x80/0xcc)
[<c047e9b8>] (dump_stack) from [<c00131e8>] (ipi_cpu_stop+0x3c/0x6c)
[<c00131e8>] (ipi_cpu_stop) from [<c00137d0>] (handle_IPI+0x64/0x84)
[<c00137d0>] (handle_IPI) from [<c00085e8>] (gic_handle_irq+0x54/0x5c)
[<c00085e8>] (gic_handle_irq) from [<c0011700>] (__irq_svc+0x40/0x74)
Exception stack(0xee86df70 to 0xee86dfb8)
df60:                                     8d058872 00000000 8d058872 00000000
df80: eefe1e08 00000000 8cab5962 00000000 c06c2280 00000001 00000000 c0485848
dfa0: 00000008 ee86dfb8 c00600dc c0376b20 90000113 ffffffff
[<c0011700>] (__irq_svc) from [<c0376b20>] (cpuidle_enter_state+0x50/0x108)
[<c0376b20>] (cpuidle_enter_state) from [<c0049090>] (cpu_startup_entry+0x1a8/0x268)
[<c0049090>] (cpu_startup_entry) from [<00008684>] (0x8684)
---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
root@zynq:/proc/sys/kernel# more sem
32000   1024000000      500     32000
Not sure exactly what these numbers mean.  I am still trying to get a larger rootfs in place.
Was sidetracked on some different work for a few days and now trying to get back into this...any help appreciated.
This is what led me down the rootfs path... it appears that there is no space left in /dev
root@zynq:/proc/sys/kernel# df -k
Filesystem           1K-blocks      Used Available Use% Mounted on
devtmpfs                    64        64         0 100% /dev
tmpfs                   516240        16    516224   0% /run
tmpfs                   516240        16    516224   0% /var/volatile
df -h results:
/devtempfs is 64k and 100% used
/proc/sys/kernel/sem is 32000  1024000000  500 32000
Picking this back up after a short detour...any advice appreciated!
Scholar rfs613
You could try resizing it explicitly:
mount -oremount,size=1M /dev
If that helps, then we'll have to track down why your devtmpfs is being created with ony 64k, as opposed to the tmpfs default which is 50% of your RAM size.
