Scholar vanmierlo
sftp not working in petalinux 2016.4
Strange things are happening in the rootfs of petalinux 2016.4.
I have configured it with petalinux-config -c rootfs and selected to install dropbear, dropbear-openssh-sftp-server and openssh-sftp-server. And I can certainly log in using ssh, but when I try to use sftp I get an error saying 'sh: /usr/libexec/sftp-server: No such file or directory'.
This 'file' is present in the filesystem as a link to a non-existing file /usr/lib/openssh/sftp-server.
lrwxrwxrwx    1 root     root          28 Feb 14 14:40 /usr/libexec/sftp-server -> /usr/lib/openssh/sftp-server
Shouldn't this last file be installed by my selection of openssh-sftp-server ?
I also observed that even though udhcpc is marked as do-not-install, it does exist in my filesystem. What gives? Am I no longer supposed to use petalinux-config -c rootfs ? If not, what else should I use?
And in the short term, what am I supposed to do to get sftp working?
Maarten
Re: sftp not working in petalinux 2016.4
Hi Maarten
The dropbear-openssh-sftp-server behavior currently prevents sftp-server from running.
To work around this issue, disable the "Dropbear-sftp" option in "petalinux-config -c rootfs", then run "petalinux-build".
Let me know if this works for you.
Best Regards
Shabbir
Scholar vanmierlo
Also, I seem to have my system wide open for ftp access! I can't even find an option to switch on/off ftp in the rootfs configuration.
Scholar vanmierlo
Update: It seems inetd is starting ftp and telnet. WTF? And that while inetd is marked not to be installed!
Hi Maarten
Best Regards
Shabbir
Scholar vanmierlo
Ok, that was unexpected. But it seems to work.
I, too, am having this problem, now that I have a running system built on Petalinux 2016.4, and running on the ZC706.  I have the following in my configuration: dropbear (and no others in the Dropbear list) and openssh-sftp-server (and no others in the openssh list).  When I run sftp to connect to the ZC706 target, this is what results:
$ sftp root@192.168.10.1
root@192.168.10.1's password:
Connection closed
I cannot find a /usr/libexec directory, nor can I find sftp-server anywhere.
It has a link to another non-existing file:
root@uz_pluart:/usr/libexec# ls -la
total 0
drwxr-xr-x    2 root     root            60 Feb  9 16:12 .
drwxr-xr-x   10 root     root           200 Dec 13 20:00 ..
lrwxrwxrwx    1 root     root            28 Feb  9 16:12 sftp-server -> /usr/lib/openssh/sftp-server
Scholar vanmierlo
Funny (not really), how this is still not fixed after 12 months in Petalinux 2017.4.
