chaitusvk
signal from kernel to application
In petalinux i am writing driver for axi counter with interupt .. i am using signal to inform my app that counter value incremented
in irq handler in driver i added
static irqreturn_t mymod_irq(int irq, void *lp)
	//printk("mymod interrupt\n");
	struct siginfo info;
    //printk(KERN_INFO "Shared IRQ: Interrupt Occurred");
    //Sending signal to app
    memset(&info, 0, sizeof(struct siginfo));
    info.si_signo = SIGETX;
    info.si_code = SI_QUEUE;
    info.si_int = 1;
    if (task != NULL) {
        printk(KERN_INFO "Sending signal to app\n");
        if(send_sig_info(SIGETX, &info, task) < 0) {
            printk(KERN_INFO "Unable to send signal\n");
	return IRQ_HANDLED;
i am getting error as shown in send_signal_info
How to send signals from kernal to userspace
boba-milk-tea
You need to include these in your source <linux/sched/signal.h> and <asm/siginfo.h>
Also typecast to (struct kernel_signinfo *) when calling send_sig_info()
Give this a try:
#include <linux/sched/signal.h>
#include <asm/siginfo.h>
static irqreturn_t mymod_irq(int irq, void *lp){
    info.si_int = 1;
    if (task != NULL) {
        if(send_sig_info(SIGETX, (struct kernel_siginfo *) &info, task) < 0) {
	return IRQ_HANDLED;
