se17828
software development
Hello, i finally have the linux kernel on my SP605 and now i want to get one with software development. Until now to cross-compile extremelly simple applications which only used printf and other simple functions i used the command "mb-linux-gcc souce.c" (with the PATH variable correctly set). My question is, is there a better way to do this? I mean, what do people use normally? Is there some SDK prepared for this? will this simple command that i have been using fail to build more complex applications?
Thanks for your help!
this is actually not a microblaze specific task but a general Linux user space development task, so I guess it is not the right forum here.
I tell you what I do (there are plenty of approaches on how to write a complex Linux user space app):
As a C-development framework I use eclipse (see eclipe.org).
Then I use a makefile edited by hand (there are better approaches out there) which point to the correct cross-compiler.
In eclipse I simply point to this makefile (or better to the build folder where the makefile resides).
So in your case I would start  understanding makefiles.
Hop I could give you a hint.
regards,
Marco
