sschekall
standalone_v5_3 USE_AMP=1 (Linux/Baremetal) on MicroZed is Not wroking
I Ugreaded to Vivado/SDK 2015.4 and now all my AMP (Linux/Baremetal) applications fail .
The probelem is that the standalone code on CPU1 wakes up properly but never reaches main().
 I have studied  http://www.wiki.xilinx.com/XAPP1078+Latest+Information
I'm using :
current linux-xlns (make  xilinx_zynq_defconfig)
      bootparms : console-ttyPS0,11520  maxcpus=1 mem=512M root=/dev/ram rw earlyprintk
standalone_cpu1.c is compiled aginst :
standalone_v5_3 (USE_AMP=1)/cpu1 BSP
when I write to
0xfffffff0 <= 0x20000000 (from Linux)
cpu1 does wakeup and begin exicution starting at 0x20000000.
But it nevers reaches main() which is at address 0x2000544
--------------- from standalone_cpu1.elf ---------------------------
 main(void) {
20000544: e92d4830 push {r4, r5, fp, lr}
Using the debugger (breakpoint set at 0x20000000) I've confirmed that main is indeed at 0x20000544.
But I cannot understand why cpu1 ends in in the weed somewhere between 0x20000000 and 0x20000544.
I need help
Is there something wrong with BSP (standalone_v5_3)?
Is Linux somehow corrupting the CPU1 code in memory  (0x20000000-0x1ff00000)
Is L2 Cache not properly disabled ??
Some one please help.
sampatd
Can you please attach your zipped workspace here?
sschekall
workspace attached
johnmcd
Since you are using a non-modified version of bsp, the bsp will be modifying the mmu to use ddr at 0x00000000 when you address 0x20000000 since USE_AMP=1. As a quick fix, copy standalone_v5_3 to a local sdk repository and comment out lines 220 through to 231 in src/cortexa9/gcc/boot.S. You will need to create a new bsp in order for these changes to take affect and you should be able to see the modified boot.S in the sdk bsp project.
I've answered a few other threads regarding xapp1078/1079. Start here: https://forums.xilinx.com/t5/Embedded-Processor-System-Design/amp-xapp1078-1079/m-p/687746
