static library from Xilinx SDK for zynq
hi,
how can i create a static library from Xilinx SDK 2014.4 for zynq?
regards,
you may also look related information here
http://www.wiki.xilinx.com/Zynq-7000+AP+SoC+Spectrum+Analyzer+part+2++-+Accelerating+Software+-+Building+ARM+NEON+Library+Tech+Tip
Thanks and Regards
Balkrishan
