/sys/bus/iio/devices/iio:device0?
What is the meaning of the file under the /sys/bus/iio/devices/iio:device0 directory, which represents the voltage, as shown in the following figure
Re: /sys/bus/iio/devices/iio:device0?
Hi @xilinx-zhaosheng
Basically you can use the application that is provided with the XAPP1172 to read the values in mV and degrees. Otherwise just read the files (using cat command) and convert to the desired scale using the right conversion values according to your configuration.
You can take a look to the code provided to as an example.
Ibai
It is all described in the device data sheet. Read it thoroughly.
The device0 within the IIO framework is the system monitor or XADC within the Zynq SoC, so those voltages are the ones monitored by the XADC internally.
Check more information at:
Wiki page
XAPP1172
Ibai
How do I calculate the voltage through the file?
Ibai
