tcp/ip select does not work on petalinux zynq
i made a Vivado 2017.4.1 design as follows (Name: server):
 Simple Design
Just Zynq...
1. Then i build and export this design.
2. SDK -> Linux Project (Hello World)
3. petalinux-create --type project --template zynq --name server
INFO: Create project: server
INFO: New project successfully created in /home/czymic/projects/2017.4/server
4. cd Server
5. petalinux-config --get-hw-description=/mnt/hgfs/share/2017.4/server/server.sdk
"Configuration Dialog"
input: save
input: Exit
INFO: Getting hardware description...
cp: omitting directory '/mnt/hgfs/share/2017.4/server/server.sdk/Firmware'
cp: omitting directory '/mnt/hgfs/share/2017.4/server/server.sdk/RemoteSystemsTempFiles'
cp: omitting directory '/mnt/hgfs/share/2017.4/server/server.sdk/system_wrapper_hw_platform_0'
INFO: Rename system_wrapper.hdf to system.hdf
[INFO] generating Kconfig for project
[INFO] menuconfig project
/home/czymic/projects/2017.4/server/build/misc/config/Kconfig.syshw:30:warning: defaults for choice values not supported
/home/czymic/projects/2017.4/server/build/misc/config/Kconfig:568:warning: config symbol defined without type
*** End of the configuration.
*** Execute 'make' to start the build or try 'make help'.
[INFO] sourcing bitbake
[INFO] generating plnxtool conf
[INFO] generating meta-plnx-generated layer
~/projects/2017.4/server/build/misc/plnx-generated ~/projects/2017.4/server
[INFO] generating machine configuration
[INFO] generating bbappends for project . This may take time !
[INFO] generating u-boot configuration files
[INFO] generating kernel configuration files
[INFO] generating kconfig for Rootfs
Generate rootfs kconfig
[INFO] oldconfig rootfs
[INFO] generating petalinux-user-image.bb
6. petalinux-build
[INFO] building project
INFO: bitbake petalinux-user-image
Parsing recipes: 100% |###################################################################################################################| Time: 0:01:29
Parsing of 2466 .bb files complete (0 cached, 2466 parsed). 3259 targets, 226 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
Initialising tasks: 100% |################################################################################################################| Time: 0:00:06
Checking sstate mirror object availability: 100% |########################################################################################| Time: 0:00:10
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
fsbl-2017.4+gitAUTOINC+77448ae629-r0 do_compile: NOTE: fsbl: compiling from external source tree /home/czymic/petalinux/2017.4/tools/hsm/data/embeddedsw
NOTE: Tasks Summary: Attempted 2444 tasks of which 2395 didn't need to be rerun and all succeeded.
INFO: Copying Images from deploy to images
INFO: Creating images/linux directory
NOTE: Failed to copy built images to tftp dir:  /tftpboot
[INFO] successfully built Project
7. petalinux-package --boot --force --fsbl images/linux/zynq_fsbl.elf --fpga images/linux/system_wrapper.bit --u-boot
INFO: File in BOOT BIN: "/home/czymic/projects/2017.4/server/images/linux/zynq_fsbl.elf"
INFO: File in BOOT BIN: "/home/czymic/projects/2017.4/server/images/linux/system_wrapper.bit"
INFO: File in BOOT BIN: "/home/czymic/projects/2017.4/server/images/linux/u-boot.elf"
INFO: Generating zynq binary package BOOT.BIN...
INFO: Binary is ready.
WARNING: Unable to access the TFTPBOOT folder /tftpboot!!!
WARNING: Skip file copy to TFTPBOOT folder!!!
8. Write Firmware:
#include <stdio.h>
#include <arpa/inet.h>
#include <unistd.h>
#define SOCKET_ERROR -1
#define INVALID_SOCKET SOCKET_ERROR
#define CHANNEL_BUFFER_SIZE 4
int main()
    printf("Hello World\n");
    struct sockaddr_in server_addr = { 0 };
    struct sockaddr_in client_addr = { 0 };
    int s_server = socket(AF_INET, SOCK_STREAM, IPPROTO_TCP);
    server_addr.sin_family = AF_INET;
    server_addr.sin_port = htons(5000);
    inet_aton("0.0.0.0", (void*) &server_addr.sin_addr.s_addr);
    if (bind(s_server, (void*) &server_addr, sizeof(server_addr)) != INVALID_SOCKET)
        if (listen(s_server, 1) != INVALID_SOCKET)
            int s_client = INVALID_SOCKET;
            socklen_t nSize = 0;
            if ((s_client = accept(s_server, (void*) &client_addr, &nSize)) != INVALID_SOCKET)
                fd_set fds;
                FD_ZERO(&fds);
                FD_SET(s_client, &fds);
                select(1, &fds, NULL, NULL, NULL);
                if (FD_ISSET(s_client, &fds))
                    printf("Data received!\n");
                    close(s_client);
    return 0;
This Firmware is waiting for an incomming Connection on port 5000 and is waiting on receiving Input data. if it receives any data it closes the Connection. Thats all.
9 Test Firmware on zynq (Server design with default petalinux configuration)
Result: The firmware is able to establish the connection but select does not return even if data is present.
10. Writing Windows Consolen App with Visual Studio 6.0
#include "stdafx.h"
#include <stdio.h>
#include <winsock2.h>
#pragma comment(lib, "ws2_32.lib")
int main()
   WSADATA wsa = { 0 };
   if (WSAStartup(MAKEWORD(2, 2), &wsa) == 0)
       server_addr.sin_addr.s_addr = inet_addr("0.0.0.0");
       if (bind(s_server, (SOCKADDR*) &server_addr, sizeof(server_addr)) != SOCKET_ERROR)
         if (listen(s_server, 1) != SOCKET_ERROR)
           int nSize = sizeof(client_addr);
           if ((s_client = accept(s_server, (SOCKADDR*) &client_addr, &nSize)) != INVALID_SOCKET)
             int nSelect = 0;
             fd_set fds;
             FD_ZERO(&fds);
             closesocket(s_client);
       WSACleanup();
     return 0;
This Windows Consolen App is equivalent to the Linux App (Firmware see 8.) it has two differences:
a.) It Needs a WSAStartup call to initialize tcp/ip on Windows.
b.) It works.
Now my question:
What must i do to enable the select functionality on petalinux?
Thank you...
I would guess the problem is here:
The first argument needs to be the highest file descriptor plus one. So try this:
select(s_client + 1, &fds, NULL, NULL, NULL);
Under Windows it probably works to use hard-coded 1, but in Unix / Linux / petalinux, all programs inherit three file descriptors when they start:
  • 0 = stdin
  • 1 = stdout
  • 2 = stderr
So that means that the lowest possible file descriptor for s_client will be 3.
(edit: fix typo on stdin/sterr)
  • 0 = stdin
  • 1 = stdout
  • 2 = stderr
