the configuration of petalinux
BOOT.BIN that maked by zynq_fsbl.elf and u-boot.elf is placed in QSPI-Flash. System.bit and uImage,devicetree.dtb are placed in SD.How to configure petalinux to meet this requirement.
thanks!!!
shirilt
Hi 1993833617@qq.com
Please refer to p. 79 of https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_1/ug1209-embedded-design-tutorial.pdf to get directions for booting using QSPI flash. Also p. 49 of the same guide describes how to create petalinux images for booting from QSPI flash.
Best,
Shiril
thanks , i modify petalinux-config,u-boot(ext-local-src),use own source code and modify platform-auto.h.
