time.h question
so i'm using time.h to measure program time running on petalinux zynq
begin = clock();
program etc
end = clock();
time_spent = (double)(end - begin) / CLOCKS_PER_SEC;
the CLOCKS_PER_SEC =1000000
is CLOCKS_PER_SEC correct for any system or i need divide by some new number?
I would think clocks per second depends on the cpu frequency so you need to scale it with it to get actual times.
yea but zynq cpu is running at 667mhz, if i use that my dma time just dont look right, much too small.
