too many arguments to function 'get_user_pages'
linux 2016_r2, When I enable xilinx apf accelerator in .config, and build the linux, an error occurs:drivers/staging/apf/xilinx-dma-apf.c:659:5:  error: too many arguments to function 'get_user_pages'.
and then I download the linux 2017_r1, and replace the apf file floder of linux 2016_r2 with the floder in linux 2017_r1,the the error changed as:drivers/staging/apf/xilinx-dma-apf.c:665:5: error: too few arguments to function 'get_user_pages'
the log output when build linux 2016_r2 as below:
drivers/staging/apf/xilinx-dma-apf.c: In function 'pin_user_pages':
drivers/staging/apf/xilinx-dma-apf.c:665:5: warning: passing argument 1 of 'get_user_pages' makes integer from pointer without a cast [enabled by default]
include/linux/mm.h:1266:6: note: expected 'long unsigned int' but argument is of type 'struct task_struct *'
drivers/staging/apf/xilinx-dma-apf.c:665:5: warning: passing argument 2 of 'get_user_pages' makes integer from pointer without a cast [enabled by default]
include/linux/mm.h:1266:6: note: expected 'long unsigned int' but argument is of type 'struct mm_struct *'
drivers/staging/apf/xilinx-dma-apf.c:665:5: warning: passing argument 5 of 'get_user_pages' makes pointer from integer without a cast [enabled by default]
include/linux/mm.h:1266:6: note: expected 'struct page **' but argument is of type 'int'
drivers/staging/apf/xilinx-dma-apf.c:665:5: warning: passing argument 6 of 'get_user_pages' makes pointer from integer without a cast [enabled by default]
include/linux/mm.h:1266:6: note: expected 'struct vm_area_struct **' but argument is of type 'int'
drivers/staging/apf/xilinx-dma-apf.c:665:5: error: too many arguments to function 'get_user_pages'
include/linux/mm.h:1266:6: note: declared here
drivers/staging/apf/xilinx-dma-apf.c:710:4: warning: implicit declaration of function 'page_cache_release' [-Wimplicit-function-declaration]
drivers/staging/apf/xilinx-dma-apf.c: In function 'xdma_submit':
drivers/staging/apf/xilinx-dma-apf.c:875:3: warning: passing argument 1 of 'phy_buf_to_sgl' makes pointer from integer without a cast [enabled by default]
drivers/staging/apf/xilinx-dma-apf.c:543:21: note: expected 'void *' but argument is of type 'xlnk_intptr_type'
scripts/Makefile.build:291: recipe for target 'drivers/staging/apf/xilinx-dma-apf.o' failed
make[3]: *** [drivers/staging/apf/xilinx-dma-apf.o] Error 1
scripts/Makefile.build:440: recipe for target 'drivers/staging/apf' failed
make[2]: *** [drivers/staging/apf] Error 2
scripts/Makefile.build:440: recipe for target 'drivers/staging' failed
make[1]: *** [drivers/staging] Error 2
Makefile:959: recipe for target 'drivers' failed
make: *** [drivers] Error 2
so what should i do to solve it? thank you.
